Ashi Posted March 23, 2014 Share Posted March 23, 2014 Hey guys this the exhaust i got and I'm thinking of putting a 3inch exhaust tip but mines a non turbo will i lose any power Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/ Share on other sites More sharing options...
Captain Natro Posted March 23, 2014 Share Posted March 23, 2014 Kathryn just made 93rwkw with her non turbo, power isn't a concern... Do whatever you please Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7236456 Share on other sites More sharing options...
Cadmoon Posted March 23, 2014 Share Posted March 23, 2014 Changing the tip will have almost no effect on power, changing the exhaust will more than likely see a drop in power for you. Also if your are cutting off the rear muffler and putting a cannon on you will get a lot of droning. Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7236474 Share on other sites More sharing options...
MagicMikeZ32 Posted March 23, 2014 Share Posted March 23, 2014 It is a bad idea. Keep what you have. Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7236920 Share on other sites More sharing options...
GTS R33 Posted March 23, 2014 Share Posted March 23, 2014 Just a quick question while we have an exhaust topic. Will I lose power putting a rear muff/res back on. Just want a quieter ride, thinking to get dump pipe upgrade, cat upgrade while at it. Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7236974 Share on other sites More sharing options...
MagicMikeZ32 Posted March 24, 2014 Share Posted March 24, 2014 What are you running currently? Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7237093 Share on other sites More sharing options...
Cadmoon Posted March 24, 2014 Share Posted March 24, 2014 Adding mufflers that restrict flow will cause a loss in power but it will probably only be a small one, resonators are a better bet but they won't cut as much noise. Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7237098 Share on other sites More sharing options...
GTS R33 Posted March 24, 2014 Share Posted March 24, 2014 I think it may already have a res there is a little section on the piping looks like a foot long bubble behind the cat Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7237487 Share on other sites More sharing options...
Cadmoon Posted March 24, 2014 Share Posted March 24, 2014 Yeah resonators look like slightly bulged sections. I believe you can put multiple resonators in tho to reduce the noise. Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7237510 Share on other sites More sharing options...
Captain Natro Posted March 24, 2014 Share Posted March 24, 2014 I run a center resonator and a rear muffler and mines still half noisy Link to comment https://www.sau.com.au/forums/topic/440913-3inch-exhaust-tip/#findComment-7237732 Share on other sites More sharing options...
