I have a 1990 E-BNR32 here in QLD, every single bit of japanese paperwork about the car before she got on the boat, never been in accident & dead straight chassis, original engine, 129,000kms, original gun grey paint (came with N1 bodykit but had frp bonnet lip and boot lip painted), complete mint interior, brembo swap, complete suspension system overhaul with solid bushes and all adjustable arms (hicas has been replaced with adjustable toe arms), sits on a set of work emotion XT7's and wrapped in AD08'S
While engine is internally stock the car did come from Japan with a few bolt on mods, I've added a few myself and actually have parts to transform it into a 360awkw beast.
I would love to upgrade to a BNR34 and that would be my only reason to sell my car, given my car is pretty much what you're after it seems a good time. if you're interested feel free to contact me and I can give you any info you want, if not good luck with your search :)
I appreciate the reply mate, but at this stage I cant travel to QLD to have a look. If things change I will let you know.
Well I can only say that id be willing to fly up from nsw and drive it down to you and then fly home if you pay me and all the airfares and accomodation :yes:
I think your budget is also doable, but this could take a little longer to find then your willing to wait
If you really want a gtr that suits you, I'd say you have to be prepared to travel for one
We get people flying in for camrys at work so it's not that hard to do if your looking at spending 30 on a rare car
I can also safely say that I have been keeping an eye on Carsales for the past couple of years and out of a handfull of nice gtr's, only a 1/4 have been in Melbourne
This car has been up for as long as I can remember, it was up for 39990
Just a week or so ago he dropped it to 34990
I'm not sure if he is a member, but if I wanted to spend 30, I would def consider going to see this car, possibly up my budget and try to negotiate a deal with it
From what it seems this thing is an immaculate v spec. Love it
http://www.carsales.com.au/private/details/Nissan-Skyline-1993/SSE-AD-151413/?Cr=0&sdmvc=1
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
