hi
I had a few issues to my exhaust - currently from muffler to cannon ect (from bottomof dump pipe back is off) is off and I wont have time to fix it before next event - ppls have said just bolt a straight pipe on..
car is idling and running fine - havnt flogged it but on idle afr ratio is on mid 10s will this effect my tune or anything?
running rb25det 35/40 highmount all the bits - external gate - running 320kw car was running fine still is I think -
do I need a re tune or try fix exhaust? I didn't think removing that stuff you effect anything.. I am going to replace spark plugs and re upload tune as batteir has been disco (not that that would do it) I don't think..
as I rev it afr go up to round round 13 - just wanna know if it is ok to drive
thanks
https://www.sau.com.au/forums/topic/440921-exhaust-help/
Gas my self? I might sound stupid but whilst driving the exhaust still sticks out the back so not sure what you mean..
at my last drift day I noticed a lot of drift cars running strsaight pipes..
well my first drive is a cruise session and few squirts so will see how its running after that..
exhaust is tac welded to some suppor bars so not touching anywhere under the car
I was worried about that other stuff cos the way I thought it will have no restriction and gass will just flow out? got me worried now
long as tune is not effected then I will just monitor it and see
https://www.sau.com.au/forums/topic/440921-exhaust-help/#findComment-7236881
yeah mate you mentioned dropping the entire exhaust behind the dump. Weld up a straight pipe really is the way to go. plus that config is run by almost everyone anyway it will last you a couple seasons at least if you do it right
https://www.sau.com.au/forums/topic/440921-exhaust-help/#findComment-7236932
