Motogp 2014
 Share
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
    • Hoping they release an R34 getrag pull type.
    • You need the bottom spacers, to make it a 3/4 height injector. https://www.efihardware.com/products/3040/injector-adapter-lower-for-extended-nose-injectors   And you'll need to buy the right injector bosses, these "might" fit. You'll need to measure it up. https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/
