Hello :action-smiley-069:
I have a lovely set of Nismo LMGT1's for sale.
Made by RAYS for Nismo,so you know they are made JDM strong.
These are in excellent condition with hardly a mark on them (as pics indicate)
They also come with RARE Rays centre caps!
Wrapped in Dunlop R compound tyres.2x tyres are on the wear bar & 2x tyres have about 30% tread left.(tyres are still very driveable)
They are 18x9.5 with an offset of +14.They fit nicely on-
R23 Gtr
R33 Gtr
R34 Gtr & anything else you can squeeze them under.
These will clear big brakes.
Nismo LmGt1's are hard to come buy these days in good condition. Also these were made in late 2002 (as date indicates in pic)
Located on Southside of Brisbane. Welcome to come pick them up if your local.
Interstate buyers I can organise freight to you (at your cost) & generally around $130 delivery Australia wide through e-go.com.au.
Im looking for $2500
Best to call or text me as im not always on here 0452-389-598
Ready to bolt on and drive away!
  • Like 1
https://www.sau.com.au/forums/topic/440941-nismo-lmgt1s-exelent-cond-18x9514/
Pure sex. I wish I had a spare couple grand.
Those things are mint. Don't budge on price, they are worth every bit of $2,500.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
