Very straight car 80% complete will list some parts, enquire if there is anything you need
Parts not available - front bar, grill, headlights, engine mounts, engine covers - most other parts available
Rb26 Cylinder head - in very good condition with HKS 10.25 lift cams $1000
Hks fuel rail with nismo fpr - $250
ARP head studs to suit rb26 used once only - $150
Genuine OS Giken adjustable can gears good condition - $250
Instrument cluster very good condition prismatic bezel 75,000km - - $100
32 gtr dash mint condition no cracks or bubbles - $300
32 gtr seats front and rear no rips, tears or sun fade - fronts $500 the pair, rears $200
32 gtr rear spoiler gunmetal grey mint condition - $150
OS Giken twin plate clutch kit still has some meat but will need rebuild at some stage $500
32 gtr front indicators some tab damage $75 the pair
Dash binnacle with all switches including headlight in excellent condition - $100
32 gtr bonnet latch riser $100
Gtr G sensor and all wheel drive controller in excellent condition $350
Heaps of standard intercooler and BOV piping - enquire for prices
Front guards no side indicator holes $250 each
Gtr bonnet with lining - $500
Gtr rear cradle complete including diff no brakes - $600
32 gtr clock very good condition - $80
Gtr sump including diff very good condition - $250
32gtr Gear box with crossmember and shifter very good condition - $600
Pickup Ipswich
Phone: 0413 863 207
https://www.sau.com.au/forums/topic/440944-parting-out-32gtr/
  • 3 weeks later...
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
