Ive recently been thinking about putting a killswitch in my stagea. Ive sat in the drivers seat and picked out 5 places I would look for one if I was to steal a car amd can't think of another convenient place to put it so im now thinking of a proximity sensor (like an rfid key tag amd a unit under the dash or similar wired up to the fuel pump). Has anyone done this or seen this done before? Also need it time delayed or run through the turbo timer. Does anyone know of a reputable alarm specialist in Adelaide that might be able to help out with putting my words into action? As I have a poor history of auto elecricianism.. Any help or guidance would be much appreciated :)
https://www.sau.com.au/forums/topic/440963-proxy-kill-switch/
Random, but my old VL had a screw you had to hold your finger on while turning the key. I can PM the location to you of where it was, probably shouldnt announce it on here
As for how it was done... I have no idea. Screw with a wire off to somewhere. Car came like that so never bothered to check it out. It didnt have an alarm so must have just been utilising the stock electrics etc. Not sure it would even be an option on the VL.
It let everything turn on but the starter
This looks like a handy device. It suggests putting it in the fuel pump line but you could use in a number of ways to disable the car:
http://www.trademe.co.nz/Browse/Listing.aspx?id=704435597
The reason I don't like that ^ is it's another remote that you need to carry around. And either you're going to put that on your keys, which ultimately defeats the purpose because most cars are stolen via the keys; or you need to have it separate to your keys, in which case where do you keep it?
I would prefer a completely separate device, and I don't care if it takes me 5 minutes to start my car every time I drive it. The harder it is for me to start the car, the harder it will be for any potential thieves.
Thats what I liked about mine. There was no need to carry anything extra, no button, was just (AFAIK) earthing out a circuit to enable the start circuit
It was probably just the earth side of the starter signal (from the key) to the screw so it had no earth till you put your hand on the screw and then on the key (grounded through the key switch) then the car would start. If you didnt know where the screw was, the car wouldnt start.
BUT this way you could still bridge the solenoid on the starter moter and get it going etc. So its not the best way to do it. But you might be able to do something similiar with the fuel pump circuit.
This is just an idea, not sure it would work in a skyline, and it might not be what you are looking for
Ive recently been thinking about putting a killswitch my stagea. Ive sat in the drivers seat and picked out 5 places I would look for one if I was to steal a car amd can't think of another convenient place to put it so im now thinking of a proximity sensor (like an rfid key tag amd a unit under the dash or similar wired up to the fuel pump). Has anyone done this or seen this done before? Also need it time delayed or run through the turbo timer. Does anyone know of a reputable alarm specialist in Adelaide that might be able to help out with putting my words into action? As I have a poor history of auto elecricianism.. Any help or guidance would be much appreciated :)
First things first, In the name of security, get rid of the turbo timer. They give thieving f#%ks the three wires needed to start your car!!!
In regards to kill switches, many years ago in a car I don't own anymore, I fitted one in the right hand air vent (between dash & drivers door) about 2 1\2" down the duct. It ment I had a 3" long thin bit of aluminum on my key ring. 3 attempts were made to steal it, but they never got it (it was a near mint XC Fairmont 378 stroker, top loader, 9" yada yada yada).
  • Like 1
the tag can be replaced by smartphone, it it acts like an rfid device
is it similar to what viper has..?
Edited by enka
  • 3 months later...
Forgot about this thread.. something im still really keen on..
Noted and have since done so.
you are really talking a custom solution. forget traditional car audio shops..
Ill have a hunt around for specialist I s'pose
As far as 'another remote', im imagining something like a supercheap club keytag sized myki thing that when within five meters of a receiver in cabin turns the immobilizer off. Start car like usual. Outside the radius, immobilizer on.
key pass over a sensor behind the dash
this could work Edited by c34Florry
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
