Ive recently been thinking about putting a killswitch in my stagea. Ive sat in the drivers seat and picked out 5 places I would look for one if I was to steal a car amd can't think of another convenient place to put it so im now thinking of a proximity sensor (like an rfid key tag amd a unit under the dash or similar wired up to the fuel pump). Has anyone done this or seen this done before? Also need it time delayed or run through the turbo timer. Does anyone know of a reputable alarm specialist in Adelaide that might be able to help out with putting my words into action? As I have a poor history of auto elecricianism.. Any help or guidance would be much appreciated :)
https://www.sau.com.au/forums/topic/440963-proxy-kill-switch/
Random, but my old VL had a screw you had to hold your finger on while turning the key. I can PM the location to you of where it was, probably shouldnt announce it on here
As for how it was done... I have no idea. Screw with a wire off to somewhere. Car came like that so never bothered to check it out. It didnt have an alarm so must have just been utilising the stock electrics etc. Not sure it would even be an option on the VL.
It let everything turn on but the starter
This looks like a handy device. It suggests putting it in the fuel pump line but you could use in a number of ways to disable the car:
http://www.trademe.co.nz/Browse/Listing.aspx?id=704435597
The reason I don't like that ^ is it's another remote that you need to carry around. And either you're going to put that on your keys, which ultimately defeats the purpose because most cars are stolen via the keys; or you need to have it separate to your keys, in which case where do you keep it?
I would prefer a completely separate device, and I don't care if it takes me 5 minutes to start my car every time I drive it. The harder it is for me to start the car, the harder it will be for any potential thieves.
Thats what I liked about mine. There was no need to carry anything extra, no button, was just (AFAIK) earthing out a circuit to enable the start circuit
It was probably just the earth side of the starter signal (from the key) to the screw so it had no earth till you put your hand on the screw and then on the key (grounded through the key switch) then the car would start. If you didnt know where the screw was, the car wouldnt start.
BUT this way you could still bridge the solenoid on the starter moter and get it going etc. So its not the best way to do it. But you might be able to do something similiar with the fuel pump circuit.
This is just an idea, not sure it would work in a skyline, and it might not be what you are looking for
Ive recently been thinking about putting a killswitch my stagea. Ive sat in the drivers seat and picked out 5 places I would look for one if I was to steal a car amd can't think of another convenient place to put it so im now thinking of a proximity sensor (like an rfid key tag amd a unit under the dash or similar wired up to the fuel pump). Has anyone done this or seen this done before? Also need it time delayed or run through the turbo timer. Does anyone know of a reputable alarm specialist in Adelaide that might be able to help out with putting my words into action? As I have a poor history of auto elecricianism.. Any help or guidance would be much appreciated :)
First things first, In the name of security, get rid of the turbo timer. They give thieving f#%ks the three wires needed to start your car!!!
In regards to kill switches, many years ago in a car I don't own anymore, I fitted one in the right hand air vent (between dash & drivers door) about 2 1\2" down the duct. It ment I had a 3" long thin bit of aluminum on my key ring. 3 attempts were made to steal it, but they never got it (it was a near mint XC Fairmont 378 stroker, top loader, 9" yada yada yada).
  • Like 1
the tag can be replaced by smartphone, it it acts like an rfid device
is it similar to what viper has..?
Edited by enka
  • 3 months later...
Forgot about this thread.. something im still really keen on..
Noted and have since done so.
you are really talking a custom solution. forget traditional car audio shops..
Ill have a hunt around for specialist I s'pose
As far as 'another remote', im imagining something like a supercheap club keytag sized myki thing that when within five meters of a receiver in cabin turns the immobilizer off. Start car like usual. Outside the radius, immobilizer on.
key pass over a sensor behind the dash
this could work Edited by c34Florry
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
