Hmm doubt its CAS or AFM. Because its not throwing a primary ign code.
I wonder why its only sluggish when it starts cold but if i start it hot its heaps better.
Thinking about giving it an AT service and replace that solenoid because i know thats the reason why sometimes AT light comes on and gets stuck in 3rd (common problem after they reach 140,000)
But sluggish wise i dont think its the AT
Get a set of shift solenoids, replacement INTERNAL loom (as most of the retaining clips will most likely break as soon as you try to undo them) for the tranny, fresh oil & a pickup kit.
Check to see if you can drain the converter (if they have drain bolts - most modern ones dont!?!) without removing it, if so, drain & get enough fluid for the refill. Do you know how to fill a converter?
Cold fluid with a malfunctioning shift solenoid will cause the engine to over work, hence the knock sensor code, ecu has reached max retard......
  • Like 1
Thanks for your help, yeah i can fill a converter, you make perfect sense in what your saying also in cold fluid making it run bad and causing knock sensor, always thought it was something to do with the AT.
Will drop the pan and replace solenoids see how it goes, where can i get the kit from? I know they come in a set of 3 i believe.
Cheers for your input
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
