obviously something is drawing down on the power. So yeah check all ancillary gear (interior lights etc..) and earthing straps.
I've experienced and heard a lot of people with R32 GTR's who cant leave their GTR sitting for a week or longer period of time. Some of the blame is the car alarm drawing down on the battery.
I did have the several small watch type batterys powering the m80 mongoose alarm drain after several years and had the siren part replaced.
(after ripping out the alarm and smashing it as it makes that orrible dull sound when going flat ....)
Buy a charger and put it on trickle charge whilst not driving it often.
Because if you just disconnect a battery lead terminal and if you have an alarm/imobiliser it will trigger the alarm !
The other thing I have found is that the spark plugs foul easily if it is idled for a while whilst stationary and then turned off, which makes it harder to start next time and drains the battery further while trying to crank over.
I like mine to start every time and on first turn of the key rather than 2-3 cranks. I drive it every other weekend so not often.
So replaced battery, alternator, starter, plugs', ignitor, fuel pump & filter
I understand that the OEM ECU detects the location of all cylinders on cranking. Some of the aftermarket ones look for the position of a particular piston (#1) being TDC so crank a few times on start-up
If your battery is tired this can be an issue.
Edited by Sinista32
Thanks for the feedback,
my money is on the alarm being the culprit ........
Will get it checked out, but in the meantime for <$80 buck I got myself a CTEK MX3.6 to charge the battery and then trickle charge it (my old battery charger was shite anyway......)
Cheers
The Baron
Boot light?
You can put a multimeter in amp mode in series with the battery (keys out of the ignition), then pull fuses to see what causes the drain measured on the multimeter to drop.
I just pull negative off the battery since the GTR is not a daily anymore.
Boot light?
boot light - cunning...... will check and try the multi meter as well
Thanks
just be mindful of which scale you put your meter on. Some cheap meters which dont have fuses are only rated for so much.... or if they are fused, try not to blow them!
I'm having a similar probem, possibly due to the bottom "ring" of the battery terminal has cracked and not making good contact onto the battery post.
Called into my local Nissan dealer to suss out a new setup.
Sit down everyone -
$200
WTF?????
So I'm going to see if I can get someone to weld it shut.
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
