I have seen on one of Robs builds he mounted it in the boot on that black bracing. I'll see if I can dig up some photos tonight.
Thats alot of extra engine oil to add and a long line going back with engine oil in it
Do you have enough room between the a/c condenser and intercooler. Also maybe under one of the guards in front of the wheel might work
I thought you would have to remove the condensor to do that I will look into under the guard cheers do you have one fitted
hey guys im fitting a accuusump i want to know what spec press sw i need to use ?
The three valves we have are 24-271 (20-25 psi EPC switch) 24-273 (35-40 psi EPC switch) and 24-275 (55-60 psi EPC switch)
which one guys as above in thread im running tomei oil pump
Your also paying him a lot of money for building your engine.
I would be seeking and using his advice even if it means it takes a bit longer to hear back from him.
True I am but I have been firing away too.many questions for the minute going to give him a call today for the first time
just a quick question with running a single turbo with ex gate do i need to run the factory bovs and pipeing ?
just get some custom piping made up. It will look 100 times better. As for the bov did you want it plumbed back in or atmo I have a turbo smart v port under the drivers side guard right under the head light facing up so if you look from under the car it's hidden. Also what ecu are you using one with a map sensor it's nice to scrap the afm also.
Im running a pfc djetro with twin maps yes . I will just plumb it back into the outlet on the turbo then just wasnt sure if they both were required the stock bovs are trust and proven I wont change out for aftermarket no need.
I'm also using the pfc dejetro but I'm only using one of the map sensors the other I wired to be used for boost sense. I would just use both of them twice as much air to flow.
Im running both of them they are already plumbed in ao I will leave them there. What type of car have you got and engine specs
I have a r33 gts-4 did have a rb26 conversion but now have a 25 soon to be 30 also. It's converted to just rwd now as it was planed to be a drift car but anyway engine specs are
S2 rb25det
6 boost with tial 44mm gate
KD t67 turbo
Full custom 3inch turbo back exhaust
Fredy plenum
Aeroflow fuel rail all speedflow fittings I'd 725cc injectors soon to upgrade to 2000cc
044 fuel pump surge take ect
Turbo smart fp800 fuel reg
S90 billet throttle body
Pfc dejetro with hand control,datalogit,boost control and wide band
GTR intercooler all 3inch cooler piping
Ls1 coils
Road tuned on e85 safe tune no knock over 15 ( I don't like to go over 30 using the pfc knock reading) and pretty rich will put it back on the dyno soon to get some numbers.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
