  On 14/04/2014 at 1:26 AM, Piggaz said:
I have seen on one of Robs builds he mounted it in the boot on that black bracing. I'll see if I can dig up some photos tonight.
Cheers man see how you go is that on gtroc ?
Thats alot of extra engine oil to add and a long line going back with engine oil in it
  On 15/04/2014 at 3:49 AM, Bick033 said:
Do you have enough room between the a/c condenser and intercooler. Also maybe under one of the guards in front of the wheel might work
I thought you would have to remove the condensor to do that I will look into under the guard cheers do you have one fitted
hey guys im fitting a accuusump i want to know what spec press sw i need to use ?
The three valves we have are 24-271 (20-25 psi EPC switch) 24-273 (35-40 psi EPC switch) and 24-275 (55-60 psi EPC switch)
which one guys as above in thread im running tomei oil pump
  On 16/04/2014 at 12:22 AM, superben said:
Your also paying him a lot of money for building your engine.
I would be seeking and using his advice even if it means it takes a bit longer to hear back from him.
True I am but I have been firing away too.many questions for the minute going to give him a call today for the first time
  On 20/04/2014 at 7:49 AM, danny14 said:
just a quick question with running a single turbo with ex gate do i need to run the factory bovs and pipeing ?
just get some custom piping made up. It will look 100 times better. As for the bov did you want it plumbed back in or atmo I have a turbo smart v port under the drivers side guard right under the head light facing up so if you look from under the car it's hidden. Also what ecu are you using one with a map sensor it's nice to scrap the afm also.
Im running a pfc djetro with twin maps yes . I will just plumb it back into the outlet on the turbo then just wasnt sure if they both were required the stock bovs are trust and proven I wont change out for aftermarket no need.
I'm also using the pfc dejetro but I'm only using one of the map sensors the other I wired to be used for boost sense. I would just use both of them twice as much air to flow.
Im running both of them they are already plumbed in ao I will leave them there. What type of car have you got and engine specs
I have a r33 gts-4 did have a rb26 conversion but now have a 25 soon to be 30 also. It's converted to just rwd now as it was planed to be a drift car but anyway engine specs are
S2 rb25det
6 boost with tial 44mm gate
KD t67 turbo
Full custom 3inch turbo back exhaust
Fredy plenum
Aeroflow fuel rail all speedflow fittings I'd 725cc injectors soon to upgrade to 2000cc
044 fuel pump surge take ect
Turbo smart fp800 fuel reg
S90 billet throttle body
Pfc dejetro with hand control,datalogit,boost control and wide band
GTR intercooler all 3inch cooler piping
Ls1 coils
Road tuned on e85 safe tune no knock over 15 ( I don't like to go over 30 using the pfc knock reading) and pretty rich will put it back on the dyno soon to get some numbers.
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
    • I bought my Bride reps from Crank Motorsport. He is, um, a trifle disorganised. I would have to look back at the e-mails to make sure I got it right, but I think he sent me normal fabric ones when I ordered the "Alcantara" ones. So he had to pay for shipping 3x and I'm sure that f**ked him off big time. And asking technical questions where nuanced English is required is a no go. It's simple English only. And....should I have bought the Alcantara ones? Well, as it turns out, they are great, feel great, etc, but the fabris wore through on the point of the waist bolster in <2 years. Must have caught a rip from a rivet on jeans or shorts, or something like that. So now I have to patch it somehow. A bit shit. My fault, ultimately, because it is Chinesium Faux Alcantara, not the real thing, and it turns ot that it has the tear resistance of a soggy tissue. But the seats and the reails are great. I probably should have gotten the R34 style ones, and now that they price is up in that ridiculous sort of number, I could have sold them for a profit!
    • Another recco is to just let it rest for a while and go back and reconnect later.
    • keep an extinguisher nearby? or even better, take it out of the car to charge?
