Danny14 R33 Gtr 1996 Rips Rb26/30 Build
Sweet! I have been waiting patiently for an update.
I bet you are hanging to get it running!
Yeah i am hanging i have just been so busy and on over seas trips and also setting uo my own business so i have kinda swept it to the side for a bit its killing me looking at such a mint cond 33 gtr sitting in garage wirh no engine
I got some brand new id 2000s and a custom billet twin entry rail that came off a 1200 hp 32gtr so I think I will be flowing sweet.
Just need to wait for the engine to come back and rips fuel system bolt all the fuel system im and sort out the plumbing what do you guys do run tefl9n flewi p clamped up chasis -8 to both fuel rail and reg or -6 what would be better ?
  • Like 1
  • 2 months later...
Ok guys engine has landed in Australia now will be sitting on my engine stand very soon
Quick question i have re moved standard rb26 oil filter housing im running a greed ex oil cooler kit with remote filter is it best to wack an rb20 filter housing on the engine to screw the oil kit adapter plate on ?
Got a pick of the kit, mine have always just gone on where the filter bolts onto the factory oil/water heat transfer
Is it oil cooler only or relocator to ?
If just cooler the Z145A might not fit correctly, I use a Z131 instead ( will have to double check that to be 100%, it's been a while since I have done an oil change on that car )
  • 3 weeks later...
Rips bottem end build stock 30 with prep upgrade rips baffled sump with tomei oil pump
Kelford cams head build mild port and polish with kelford 274 cam shafts and tomei cam gears
More to list i will do it soon
  • 1 month later...
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
