Will be detailing engine bay over the w.e quick question about re locating power steer resivour who has done it and do you just remove the charcoal canister and block off pipe going back to fuel tank ?
I have my power steer resivour in front of the radiator mounted to the support I got the idea from a 32 at powercruise. I have the plastic bottle and the feed hose to the pump runs under the radiator and haven't had any problems at all.
  • Like 1
Onto the fuel setup as you can see I have fitted a type s tomei fuel reg. I have replaced all the fuel lines . Except the one that has to be submersable in the fuel tank to withstand e85 fuel
I am going to run the new walbro and install it soon . do I really need a catch tank for my setup to support e85 at 600 whp ? ? Or will the walbro keep up on its own obviously with big injectors
And I was thinking of running the stock fuel rail will there be a disadvantage over an aftermarket twin entry rail if so what fuel rail should I purchase. And with running the fuel lines as twin entry do they just go from each end of the rail and join into one somehow and go to fuel filter ?
Fitted my greedy oil cooler on drivers side today had to do a little modification to mounting bracket because i no longer have stock intercooler ,still need to fit up all the lines I had to remove stock bovs
Now in the instructions for the kit it has trust bovs fitted the stock bovs will not fit with the cooler I yhat location seen as though im running a single turbo do I need 2 bovs ? Or just fit 1 in its place if so what type im not into the wanky bov noise .....
Stock BOV's. Leave them alone. They do the job, spend the money elsewhere.
I have already removed them to fit the oil cooler as per grex instructions to fit it drivers wheel arch.
So I need a different bov to fit its the only reason I removed them so the cooler would fit . As im running single turbo do I only need one bov
My opinion for the fuel system is to run a surge that way no mater what fuel level you have in your tank you always have a good constant, pressurised supply of fuel to the engine
I would advise throwing a dual entry fuel on it aswell me and the girlfriends car needed dual entry rails at 460rwhp on united p100
the tuner said it wasn't a issue with the presure it was an issue with volume I ended up running from my 2lt surge with a 044 fuel pump -10 tefflon braided supply line to regulator.
I then ran a -8 tefflon braided return line to the regulator
I then ran 2x -6 or -8 (cant remeber what size I think it ws -8) teflon braided lines to each end of the rail
and a return fuel line from the middle of the rail to the regulator
for 600rwhp on E85 you will need high volume and good pressure so it may be worth running 2x 044 pumps and a walbro intank lift pump to keep the surge well supplied with fuel
I've just upgraded from a Walbro e85 pump to a surge tank and twin 044's. Car was making 588hp on the Walbro but it was leaning out up top. I wouldn't push one of these walbros past 500-520hp. If yours chasing 600 or more I'd look into an external setup. For the extra bit of cash it's worth making sure the motor doesn't lean out and wreck what you've just built
  • Like 1
If you have blocked off your charcoal canister, make sure you have it venting somewhere. I just left mine open to atmosphere at the back, though can't say I highly recommend doing that, E85 being hydroscopic and all. Your fuel tank needs to vent though.
I have a 044 intank now
So if I just run a surge tank and two more 044s ? External osnt that overkill has anyome got a r33 gtr and where do they mount the surge tank ??
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
