Is this catch can going to be big enough for my setup welding two -12 fittings on it one in middle and one at bottom and 2 lines from yhat running to top of sump.
Its a split tank that was already on the car it has window washers and oil the other side as you can see .
Fitted my greedy oil cooler on drivers side today had to do a little modification to mounting bracket because i no longer have stock intercooler ,still need to fit up all the lines I had to remove stock bovs
Now in the instructions for the kit it has trust bovs fitted the stock bovs will not fit with the cooler I yhat location seen as though im running a single turbo do I need 2 bovs ? Or just fit 1 in its place if so what type im not into the wanky bov noise .....
I got the stock bovs to fit but outlet pipe sits abit low and inner guard fouls on it cant win ha ha
You only really need to drain it to the sump if you're going to be doing some circuit work. In that case two -12 breathers of the cam covers to the top of the can and either one -8 or bigger drain at the bottom of the can to the top of the sump. If you want to let the crankcase vent from the sump you can add a second line from the top of the sump to the top of the can. Even if you don't plan to do track work I'd be welding all of the extra fittings to the catch can and sump while it's apart so if the day does come where you need them it's an easy job
Also keep in mind if the car will be doing a lot of street k's the drain is going to mean more frequent oil changes due to all the condensation on short trips.
  • 3 weeks later...
Hey guys been very busy with my new buisiness but head is complete sitting in nz ready to send to rob amd my bottom end is also complete rob is just waiting for head
With fuel setup is a 2.5 litre catch can good enough for my powrr figure with 2 bosch 044s ex and 1 internal ?
Rob has fitted 2 -12 fittings to sump so I can run one to bottom of catch can and one to middle of catch can and I already have my 2 -10 lines running from top of catch can to each rocker cover
The size of of the surge tank will have have no impact on how much power the fuel system is capable of,it is only going to effect the surge resistance of it.
Having said that I would say it will be fine. You can get away with no surge tank depending on fuel tank level.
Can't wait to see this run soon!
Ok im noe up to the stage of doing fuel setup and new electronic gauges what are some good gauges to purchase that are well priced Im looking at removing the stock ones in the centre of the dash and replacing with new ones well 2 of them anyways
Problem with small capacity surge tanks is they heat soak quickly, my custom one is 8.5ltr and I am looking into a new bigger one as it starts to heat soak fairly quick
If not track car twin intank it with either 044s or Walbro E85 pumps and carry 1/2 tank min for track use and you won't have an issue
Breathing from the sump is ok for a street car but if you do it for a track car the catch can will quiet quickly over fill and make a mess of your engine bay, especially if you have breathers in the can it self, run a line from the bottom of the catch can to sump by all means but put a one way valve in it to allow oil in to sump but not vise versa
Better off having the return from the rail going straight back to the main tank not into the surge.
2.6ltr is fine if you do it this way, you just have to make sure the intank pump/s out flow the main pumps
That's the same sort of useage I'm doing, so no 2.6 will heat soak quiet quickly and you be pumping heated fuel into the engine, 2 x 044s will turn the fuel around a lot faster from the engine then the 1 044 intank can flush the heated fuel from the surge tank
Should do as there is no pressure.
New setup will be biggest electric Weldon out of main tank to surge and a Weldon mech pump to the rail, woo.
I've got the weldon 2025 as my main and the walbro E85 as my lift, I hate the Weldon, it is the loudest farkin thing I have ever heard :(, the pump is rubber mounted the bracket that holds the pump is rubber mounted the plate that the bracket is mounted to is rubber mounted and there is a price of -12 Kevlar braided between the pump and surge tank, am going to custom a 10ltr with twin walbro E85 intanks, cause street car > race car
  • 2 months later...
I know its been a long time but progress is coming along my engine is finished at rips in nz i also have purchased a full fuel setup from rips aswell to fit in the rig
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
