i used to drive my s2 rs4s from rockdale to rydalmere, so about 25-30km and i averaged about 500-550 before the light came on. i did drive it a bit hard at times though.
on e10 i got about 450km before the light came on
  • Replies 42
I got 485 from 59.5 litres....winch included 200+ driving to PI for tough mudder a couple weekend ago. Was expecting better, but in not surprised at how crap that is.
I've not worked out the L/100 km's but I'm lucky to get 330km's out of a full tank :(
i feel better reading this, im really lucky to get above 350k' on premium, i live in the hills, is a rather windy road on the way to work, up and down hills etc, so even driving grandma spec still not getting great economy, sometimes i wander if a manual conversion would be worth it,
(have been told manual is a bit better on economy)
Figure out how much fuel you would have to save to pay off conversion. I think it would not be worthwhile for that reason alone. A tune would be way more worthwhile, and a new O2 sensor.
LITRES PER HUNDRED PEOPLE!
I don't think a manual is much more economical. Not from anecdotes around here anyways. The problem is comparing cars in an equal state of tune and maintenance, and the only difference is the transmission. Very hard to make that comparison. The cost of a conversion will take many years to pay off, thats of course assuming you even make a difference to economy.
The best tip is to work with the transmission, keeping the converter clutch locked as much as possible. In an series 1 that means using the overdrive switch, you'll have to judge how the tiptronic is working.
Since you have a series 2, its easier for you to tune at a reasonable price.
I have had my stag for a week now.
On LPG it seems to do 19L/100km.
I haven't really run it on Petrol to be able to give accurate results.
One question though : there is an on and off switch with a steering wheel on it in the centre console. Does anyone know what that's for?
2000 Model Stagea RS4 V
My economy has not changed at all since doing the manual swap, only thing is its heaps better to drive and you don't have to predict what the stupid auto is going to do when excelerating.
That annoys me too so I manually change the gears a lot. Don't know if that helps with fuel economy but I like to try and stop it from changing gears all the time especially going up hills and when you have to stop/start at road works etc.
Yeah it doesn't really inspire confidence does it?
Especially on the twistys when you want to power out of corners.
Driving uphill, or corners really necessitates manual control over the box. I drive a selection of modern cars too, like camrys, i45s, commodores, cruzes, DSG focuses.....none of them have satisfactory shift logic for corners, or even uphill.
The worst one ever was the holden epica. The ratios were awful, and the shifts were hilariously laggy. What a shit car.
Anyhow, I can still get plenty of control with the S1 auto box.
Apart from the tiptronic ability, a shift kit really livens the box up...if you dont mind the hektic 1st to 2nd gear slam. All other gear shifts are very quick and often less noticeable than stock.
Just drove to Winton and back from Melbourne. rs4s towing about 2tn of s13/trailer and got 17lt/100kms. Much better than i expected. 4 gear all the way 3.5-4krpm. for comparison i usually get 13lt/100km everyday driving.
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
