Aftermarket parts galore
Tomei sump baffle $150
Nismo fuel reg $100
Denso 740cc injectors rb26 direct fit $380
Manley rods h beam used rb26 $300
Mahle forged pistons 86.5 rb26 $400
Apexi avcr black edition comes with manuals etc complete $300
Xforce stainless dump pipes for rb26 with O2 sensors $150
N1 turbo steel wheel rebuild kit for standard r32 r33 Gtr turbos $100
Rb26 stainless front pipe $100
Apexi turbo timer $30
Greddy turbo timer $30
Blitz turbo timer $20
Hks turbo timer $20
Turbosmart boost controller solenoid $30
Splitfire gauges $30 each
Auto meter boost gauge 60mm $30
Tein Coilovers spanners $50
Drift boost gauge $30
Yellow earthing kit $20
R33 Gtr genuine strut brace front and rear $70 each
Nardi boss kit $50
Turbosmart supersonic bov $50
Gold Coast
0487924497
post-50709-0-87871000-1395716350_thumb.jpgpost-50709-0-95324200-1395716432_thumb.jpgpost-50709-0-84236600-1395716500_thumb.jpgpost-50709-0-97840000-1395716566_thumb.jpgpost-50709-0-73955300-1395716665_thumb.jpg
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
