Hey all
Have the following for sale from a midnight purple series 2 r33 anniversary edition
Series 2 head lights 300
Front seats with 40th anniversary on it. No rips etc one missing the lever 300
Centre console 100
Front n rear door trims exc condition 300
Seat belts front n rear 200
Glove box 50
Rear parcel shelf exc condition 150
Plastic dash surround with air vents etc exc 175
Rear seats 100
Two space savers 50 each
Heaps of aircon stuff
Floor mats 75
Dump pipe n front pipe with O2 sensor 275
Bonnet 175
Digital climate control 75
Series 2 steering wheel with air bag 250
Genuine ganador mirrors 430
All in adelaide
All prices very neg
https://www.sau.com.au/forums/topic/441022-r33-parts/
mats
Driver has slight wear
All could use a good clean
Headlights.
No yellowing
One has been repaired at the back. Didnt know this until i removed it over the weekend. one side good.
couple broken clips but held onto the car fine and didnt move or rattle. also didnt let in water. looks perfect when fitted.
But open to offers
https://www.sau.com.au/forums/topic/441022-r33-parts/#findComment-7244402
forgot to mention also come with a catco cat
Came off of a r33 gtst with standard turbo.
Few dents and marks but works fine.
Would look good with a polish.
offers?
https://www.sau.com.au/forums/topic/441022-r33-parts/#findComment-7246975
Can you sends me pics interested in interior parts in excellent cond. chasing new dash surround and the part below it that goes around the gear stick I think. Need new drivers side a pillar trim and would take door trims and parcel shelf too if in better cond than mine.
https://www.sau.com.au/forums/topic/441022-r33-parts/#findComment-7248385
Hey man, just wondering if you have any other interior stuff that's not listed? I'm after the RHS power window switch plastic surround and the plastic steering column surround. Cheers, Brenton.
https://www.sau.com.au/forums/topic/441022-r33-parts/#findComment-7249752
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
