Hi guys,
Had a new exhaust fitted today. Full 3" turbo back. Anyway on the way home the CEL came on.
Just wondering if anyone else has had this prob after fitting there exhausts?
I do have a scan tool here but the bloody thing won't link. I'm thinking it has to be the 02 sensor.
Thanks.
https://www.sau.com.au/forums/topic/441036-cel-on-after-new-exhaust-fitted/
Hi guys,
Thanks.
Could be the warning light for the cat converter - shouldn't be too hard to fix.
You got an AXIS yeah?
Don't think our cars would throw a CEL from the O2 due to cats since the only O2 is upstream of them. Maybe it wasn't screwed in tight enough and it's getting bad readings or maybe it was unplugged or wire got damaged during the install. Did you fit it yourself?
I've seen loose ones on other cars cause engine lights so I'd try check that or visual check the wiring to it.
There is no cat warning light. Good chance it is the ecu going into lean limp mode. The ecu should have been reset after such a serious mod, now it needs to be reset so it learns the new fuel requirements.
You can't just use an obd2 reader, none of them connect. Our car isn't obd2 compliant.
Possibly P0420 code. Not unusual for picky ECUs with aftermarket exhausts.
As Scotty mentioned, ECU reset and see if that helps. If it pops up again, throw a can of upper head cleaner through it, that has fixed a few P0420s for my clients.
Worst case, rip the cat off and clean it properly.
Absolute worst case, move the cat/O2 sensors to near factory positions.
Hope it helps.
Mark :)
Dave, yeah axis. And I was thinking same thing... 02 is up stream so cat wouldnt effect that.
I had it made and fitted by Windsor exhaust shop. They are local with a good rep.
First thing I checked was 02 plug, and checked it was tight. Double check wiring tomorrow.
Scotty, sucks they are not obd2 compatable. What tool do I need to scan it?
How do I do a ecu reset? Is it as simple as the skylines and just disconnect the battery?
Thanks for your input guys.
http://www.skylinesaustralia.com/forums/index.php?/topic/261557-Ecu-Fault-Codes---The-Easy-Way%21
I've never posted a link to another topic so not sure that will work but the ecu reset is detailed here, if my link doesn't work try search function
Could you access the actual O2 bung on the new exhaust to check sensor tightness? My stock one is pretty much impossible to get to without a crows foot spanner bit or without dropping the gearbox crossmember all way down till you can fit a spanner up there. It's probably not an issue but maybe last resort check
Ecu reset sounds like best idea, go from there I reckon.
Dave, yes I used a crows foot to make sure it was tight.
I looked at your link. fault code is 0135 which I believe is 02 sensor. but I could not get the procedure to clear the code to work.
surely the procedure is just to give you the code and clear it...not to actually reset the ecu to learn the new fuel requirements??? correct me if im wrong.
I use a (knock off) Consult3 to diagnose, it's the only way to read all ecu's. There are other options, like the Osirus cable, but they only talk to the engine afaik. I have used a Snapon scan tool with some success, but it needs to have the Japanese software loaded. You can reset the ecu to some extent using the manual method, but I can't guarantee it will reset the long term fuel trims. Disconnecting the battery won't help.
I hope they didn't damage the sensor, it's quite tight up there... Perhaps try a new one if the code returns?
Yeah you'd need a scan tool to reset engine adaptions. If you clear the code maybe the ecu will correct itself before it stores again anyway.
I've never heard of anyone having this problem on an m35.
I wanted to buy yours Scotty but buy the time I.got the dump and front pipe from you, then a cat back from import monster or the likes, the price was getting up there and then I still would of had to install myself.
Just made more sense to get it all from the same place.
It's not on a bend. It's on the straight section between the bend just before the cat and just after first bend from turbo.
Went back to the exhaust shop today, let them know I wasn't happy and made it clear that its there responsibility to fix it. He said 02 sensor was very rusty and hard to get out so they may have damaged it then.
End of the day they are going to take care of it. I'm dropping it back to them tomorrow.
Why isn't the o2 in the stock position just after the turbo? You can't just go around moving sensors and expect them to run as per factory. Narrowband sensors need to warm up as quickly as possible, directly in front of the turbine outlet flow is the correct spot.
Where did they mount the cat, in the dump pipe?
Possibly. It's up to you to fault find this one, as I doubt the exhaust shop will help much. It's taken me 5 years to perfect my Stagea dump and front pipe, there is a lot more to exhaust design than just making a pipe from here to there...
What did they use for a turbo flange? I assume they re-used the stock one, as laser cutting a new flange one off is cost prohibitive. So it's a mild system?
It's mild pipe with stainless mufflers. I'll take some pics tomorrow when its on the hoist.
Not sure about the flange i will check whilst on the hoist.
And if they don't help! I will demand they put my stock exhaust back on and give me a full refund.
Try get them to swap the sensor and if that doesn't fix it, it'll probably have to be welded back in stock location. What else could it be? Unless you've developed a mixture changing fault that's unrelated to your new exhaust at the exact same time as getting your new exhaust.
Sensors are pretty simple but better to stick to stock locations. Maybe the flow and pressure in the pipe has changed too much to give it good readings where it's mounted now.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
