Hi guys,
Had a new exhaust fitted today. Full 3" turbo back. Anyway on the way home the CEL came on.
Just wondering if anyone else has had this prob after fitting there exhausts?
I do have a scan tool here but the bloody thing won't link. I'm thinking it has to be the 02 sensor.
Thanks.
https://www.sau.com.au/forums/topic/441036-cel-on-after-new-exhaust-fitted/
Hi guys,
Thanks.
Could be the warning light for the cat converter - shouldn't be too hard to fix.
You got an AXIS yeah?
Don't think our cars would throw a CEL from the O2 due to cats since the only O2 is upstream of them. Maybe it wasn't screwed in tight enough and it's getting bad readings or maybe it was unplugged or wire got damaged during the install. Did you fit it yourself?
I've seen loose ones on other cars cause engine lights so I'd try check that or visual check the wiring to it.
There is no cat warning light. Good chance it is the ecu going into lean limp mode. The ecu should have been reset after such a serious mod, now it needs to be reset so it learns the new fuel requirements.
You can't just use an obd2 reader, none of them connect. Our car isn't obd2 compliant.
Possibly P0420 code. Not unusual for picky ECUs with aftermarket exhausts.
As Scotty mentioned, ECU reset and see if that helps. If it pops up again, throw a can of upper head cleaner through it, that has fixed a few P0420s for my clients.
Worst case, rip the cat off and clean it properly.
Absolute worst case, move the cat/O2 sensors to near factory positions.
Hope it helps.
Mark :)
Dave, yeah axis. And I was thinking same thing... 02 is up stream so cat wouldnt effect that.
I had it made and fitted by Windsor exhaust shop. They are local with a good rep.
First thing I checked was 02 plug, and checked it was tight. Double check wiring tomorrow.
Scotty, sucks they are not obd2 compatable. What tool do I need to scan it?
How do I do a ecu reset? Is it as simple as the skylines and just disconnect the battery?
Thanks for your input guys.
http://www.skylinesaustralia.com/forums/index.php?/topic/261557-Ecu-Fault-Codes---The-Easy-Way%21
I've never posted a link to another topic so not sure that will work but the ecu reset is detailed here, if my link doesn't work try search function
Could you access the actual O2 bung on the new exhaust to check sensor tightness? My stock one is pretty much impossible to get to without a crows foot spanner bit or without dropping the gearbox crossmember all way down till you can fit a spanner up there. It's probably not an issue but maybe last resort check
Ecu reset sounds like best idea, go from there I reckon.
Dave, yes I used a crows foot to make sure it was tight.
I looked at your link. fault code is 0135 which I believe is 02 sensor. but I could not get the procedure to clear the code to work.
surely the procedure is just to give you the code and clear it...not to actually reset the ecu to learn the new fuel requirements??? correct me if im wrong.
I use a (knock off) Consult3 to diagnose, it's the only way to read all ecu's. There are other options, like the Osirus cable, but they only talk to the engine afaik. I have used a Snapon scan tool with some success, but it needs to have the Japanese software loaded. You can reset the ecu to some extent using the manual method, but I can't guarantee it will reset the long term fuel trims. Disconnecting the battery won't help.
I hope they didn't damage the sensor, it's quite tight up there... Perhaps try a new one if the code returns?
Yeah you'd need a scan tool to reset engine adaptions. If you clear the code maybe the ecu will correct itself before it stores again anyway.
I've never heard of anyone having this problem on an m35.
I wanted to buy yours Scotty but buy the time I.got the dump and front pipe from you, then a cat back from import monster or the likes, the price was getting up there and then I still would of had to install myself.
Just made more sense to get it all from the same place.
It's not on a bend. It's on the straight section between the bend just before the cat and just after first bend from turbo.
Went back to the exhaust shop today, let them know I wasn't happy and made it clear that its there responsibility to fix it. He said 02 sensor was very rusty and hard to get out so they may have damaged it then.
End of the day they are going to take care of it. I'm dropping it back to them tomorrow.
Why isn't the o2 in the stock position just after the turbo? You can't just go around moving sensors and expect them to run as per factory. Narrowband sensors need to warm up as quickly as possible, directly in front of the turbine outlet flow is the correct spot.
Where did they mount the cat, in the dump pipe?
Possibly. It's up to you to fault find this one, as I doubt the exhaust shop will help much. It's taken me 5 years to perfect my Stagea dump and front pipe, there is a lot more to exhaust design than just making a pipe from here to there...
What did they use for a turbo flange? I assume they re-used the stock one, as laser cutting a new flange one off is cost prohibitive. So it's a mild system?
It's mild pipe with stainless mufflers. I'll take some pics tomorrow when its on the hoist.
Not sure about the flange i will check whilst on the hoist.
And if they don't help! I will demand they put my stock exhaust back on and give me a full refund.
Try get them to swap the sensor and if that doesn't fix it, it'll probably have to be welded back in stock location. What else could it be? Unless you've developed a mixture changing fault that's unrelated to your new exhaust at the exact same time as getting your new exhaust.
Sensors are pretty simple but better to stick to stock locations. Maybe the flow and pressure in the pipe has changed too much to give it good readings where it's mounted now.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
