Just bought a new eboost2 controller so that with the non cat, boost leak fix, throttles tuned and e re tune should see some better results and hopefully a bigger peak power figure (:
Oh wow haha, should see some good gains soon then!
Yeah man i reckon i should see good gains haha /: 2 of the three throttle gaskets are leaking big time, the first and last injector seals are leaking, a few vacuum lines are leaking badly and there are 4 or more pin holes in the throttle adapter plate welds............ i could watch the pressure gauge on the compressor go down quite steadily after it finished filling itself and the tap was turned on to charge the intake system...
Just converted my rb25 s13 to e85. the car feels a lot faster but should it be making full boost sooner???
also puzzled at how boost and power comes on later than the bp98 .....
Has the following mods:
Standard rebuilt rb25
acl bearings
arp bolts throughout
tomei poncams
hks ex cam gear +8 i think
hks gtrs turbo kit on standard manifold,
custom japan made r32 gtr 6 throttle plenum
retains standard side feeds high flowed 740cc
greddy cooler
apexi induction kit and pod
turbosmart plumb back bov
3inch turbo back exhaust 100cell cat straight through to twin cannons
power fc
walbro 460
tomei fpr
koyo rad and greddy oil cooler
blitz spec r boost controll
excedy light flywheel
nismo 2way lsd
etc...etc..
the bottom red line in dyno 1&2 is the bp98 18psi
the middle pink line in dyno 1&2 is E85 on the same boost
the top orange line in dyno 1&2 is E85 20psi and some tweaking
dyno 3 is just differant boost settings after it was tuned obviously....
Back to original post.
1. Boost threshold should be VERY similar between fuels. I'd suggest the E85 tune is too lean on ramp up, or there is a manifold/gasket leak, or timing issue.
2. 20psi is almost certainly too much for a GTRS on an RB25 to use at the track. Just be on the look out for heat soak issues and turbo wear, depends on how much WOT you use. 16/17 psi is typically the upper limit. I'm not talking knock issues with dynamic compression since they disappear wtih E85, I'm talking turbine heat issues and compressor overspeed.
Edited by simpletool
As said in earlier post, massive boost leaks all over the inlet plenum where found after my boost leak test dude :/
The plenum set up has definitely been like this the whole time its been on the car, since dare i say "Nizzpro" put it on my car....while i was running bp98 and no change to the set up now with e85... it goes in next week to be re welded and all injectors are getting overhauled and new hks gaskets throuhgout
What's the fine for that? I'm sure you can get away with it.
You'd have to be really unlucky to end up being escorted to the inspection facility like some of the idiots who hoon around the city on a Friday night. Most of the time they just give you an EPA notice.
I was given one a year ago because the car was too loud, I just needed an excuse to drop some money on a decent catback really; previous owner thought a 4inch catback was a good idea..
You get time to get the emissions test done, enough time to bolt in the most restrictive cat you can find and pass the test. :)
If its just a sound test they wont be getting under and unbolting the cat to look inside.
This is true haha i have had my car over the pits twice and you get time to sort your defects and shit for re inspection etc
I read Joeyjoejoe's E85 Tuning Adventutres and i noticed my dyno printout has very similar characteristics (apart from the spike) to his first dyno as in the way boost comes on slowly peaks and drops off straight away.... obviously he had boost leaks and then fixed them and had a re tune and got epic little gains.... man i hope i get similar gains
http://www.skylinesaustralia.com/forums/topic/258776-joeyjoejoes-e85-tuning-adventutres/
I wasn't awere of the leaks until I had the e85 tune done and saw that my gtrs seems slower to come on boost then others I had seen so I started investigating which led me to a boost leak test and so I found a ton of leaks and am obviously getting them fixed this week as well as an eboost2, jim berry single and de cat... Hopefully I'll get in for a re tune at the end of the week or early next week... The car has not been driven since I found the leaks hey :(
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
