Our R33 has developed a noise coming from the turbo area. I'm pretty sure I know the answer (turbo stuffed) and the fix, but wanted to make sure there isn't another reason for it before pulling it all apart.
The turbo is stock as far as we know, and the rest of the engine is stock other than a 3" cat-back and an R34 SMIC. The noise is similar to the screaching sound when a drive belt slips, and is there whenever the turbo is boosting. It seems to boost as normal, and power is fine. The noise started during a supersprint event (think track day with official timing) on Sunday, but wasn't really obvious with a helmet on, and suspected a small boost leak. Driving home with helmet off it was clearly not normal.
Anyone have ideas other than the turbo itself?
https://www.sau.com.au/forums/topic/441064-r33-gtst-turbo-noise/
Exhaust manifold gasket could be stuffed, or the T3 flange warped. They can squeal like a stuck pig on boost when the manifold pressure rises...
Try the boost leaks first, and check for shaft play on the turbo while you are there.
Thanks for the replies - have already done a boost leak check & fixed a very small leak from the plug where the carbon cannister used to be connected, other than that there isn't any other leaks.
Will check the gaskets today or tomorrow. How hard is it to get to this area, what needs to be removed, and shortcuts?
Scotty - T3 flange warped - is it likely to be warped on the manifold or the turbo?
if the noise is THAT bad and its still performing as normal then perhaps the turbo is okay
Power is fine - the last few laps on Sunday were the fastest, by over a second per lap. The noise had been there most of the day, but was getting louder as the day went on. It didn't sound so bad with a helmet on.
The T3 gasket could have gone, but usually the turbo flange warps from massive heat and pressure due to track work. Not sure if the weight of the exhaust hanging off it makes it worse... I have seen it a few times on tracked cars running smaller turbo housings.
Either way you will need to check both ends of the turbo to know if it's ok or not.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
