Hey guys,
I know that this is not a skyline related topic, as we all look after our cars too well!However, my mate has just bought a cheapo XF falcon, and inside the rocker cover all the valve springs and the head in general are covered by a thick sludge up to 2cm thick in places!! How can we clean this out? Is an engine flush additive safe, or will this just shift the sludge and block up more important bits of the engine? Should we open up the rocker cover (bugger of a job) and scrape it out? Any suggestions?? (I know he should just torch it and buy a 'line, but unfortunately he can't afford it yet!)
https://www.sau.com.au/forums/topic/44109-gunk-in-engine/
pull the whole head off, its a 250 crossflow, not that big a job. Get one of those plastic 2ltr pump spray cans fill it with petrol and spray the whole shit show. Buy a VRS kit prolly 100 bucks for mono torque set and put it back together. Give him a chance to look at the condition of the thing in general
https://www.sau.com.au/forums/topic/44109-gunk-in-engine/#findComment-902695
I wouldnt use an engine flush in that case. What you'll end up doing is dislodging all the junk and then it'll possibly plug up your oil filter pickup screen. Hello no oil pressure and new bearings!
If it runs fine, just leave it! Otherwise you could try some diesel oil like Mobil Delvac 1300 (fairly cheap) and its got a tonne of detergents in it which will break it down slowly over time.
https://www.sau.com.au/forums/topic/44109-gunk-in-engine/#findComment-903480
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
