Hey guys,
I know that this is not a skyline related topic, as we all look after our cars too well!However, my mate has just bought a cheapo XF falcon, and inside the rocker cover all the valve springs and the head in general are covered by a thick sludge up to 2cm thick in places!! How can we clean this out? Is an engine flush additive safe, or will this just shift the sludge and block up more important bits of the engine? Should we open up the rocker cover (bugger of a job) and scrape it out? Any suggestions?? (I know he should just torch it and buy a 'line, but unfortunately he can't afford it yet!)
https://www.sau.com.au/forums/topic/44109-gunk-in-engine/
pull the whole head off, its a 250 crossflow, not that big a job. Get one of those plastic 2ltr pump spray cans fill it with petrol and spray the whole shit show. Buy a VRS kit prolly 100 bucks for mono torque set and put it back together. Give him a chance to look at the condition of the thing in general
https://www.sau.com.au/forums/topic/44109-gunk-in-engine/#findComment-902695
I wouldnt use an engine flush in that case. What you'll end up doing is dislodging all the junk and then it'll possibly plug up your oil filter pickup screen. Hello no oil pressure and new bearings!
If it runs fine, just leave it! Otherwise you could try some diesel oil like Mobil Delvac 1300 (fairly cheap) and its got a tonne of detergents in it which will break it down slowly over time.
https://www.sau.com.au/forums/topic/44109-gunk-in-engine/#findComment-903480
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
