Guys I'm in need of new tyres, pretty much narrowed it down to these 2,
Car is mostly street driven/spirited mountain runs with occasional drags, running 265/35/18 size
The nt05 seems like a great tyre but unsure on how many kms one would expect out of them?
And then I've herd nothing but great reviews about the nitto invo aswell, but not sure how they will go on a high powered gtr
Who Evers used these what are your thoughts, pros and cons?
Thanks
https://www.sau.com.au/forums/topic/441093-nitto-nt05-and-nitto-invo/
  • Replies 54
I had Nankang rubbish on my 336rwkw GTST and I could spin 1st - 4th under acceleration would spin wheels at 130+kph lol (was well setup suspension and diff wise too) threw the invos at it and changed my car COMPLETELY would only spin if I tromped 1st then a lil bit of a spin into 2nd then nothing but traction! Great tyre! Also great in the wet!
I had nt05s on my gtr for awhile. Thought they were a pretty good tyre, but I was stuck for choice being 19in fpr a decent price. You may be better with something like a ku36 if its cheaper?
Without knowing to much about the invos, would say the main difference of the nt05s would be better suited for track work, but may not notice the difference between the two on the street. Execpt the invos will probably be quiter and get more kms.. I would expect more than 10k kms in the nt05s though I think.
Hope that helps
With as much power as you have, I wouldn't even consider the Invos and go to the NT-05s - but i haven't used either.
If you join SAU NSW, you can get a deal on Federal RSRs which I have used and think are great (they are available in that size). RSRs are treadwear 140 compared to NT-05s @ 200, so should be a lot more grippy but wont last as long. I'd use RSRs if I had your car. No point in having huge power if you cant use it.
Hankook RS-3 and Potenza RE-11 are rated at 200 UTQG. Would you say they're better than the Federals? I read somewhere that the NT-05 is 'better' than RS-R, never driven on any tyres mentioned so I can't say, but fatz doesn't like the Federals.
How often will you be driving the car? The NT-05 if obviously not as good in the rain and won't last as long as the INVO, but with the extra contact patch, will grip better in the dry. The Corvette people love them.
Daily driving = INVO
Weekend car = NT-05
I'll be looking at putting NT-05 on once my current tyres are gone. Falken FK452 doesn't cut it any more for me :(.
Weekend car = NT-05
The RSR wont grip up on mine so i have got some RS3 for the rear... Unfortunately i couldn't get the same for the front as they are pretty much all sold out everywhere!
Boz said too my that the RS3 was the best 140 tread wear tyre in its class from his personal experience and he should know :yes:
The EVO guys all foam at the mouth about the RS-3. They are a seriously good tyre.
Well i just had 275 rears fitted so fingers crossed they are as good as they say!
you need something like R888s or something?....
they were unbelieveable on the gtr.
Will be getting a dedicated track rim and tyre setup later this year man ;)
Car was just cornerweighted etc so will see how it feels!
Thanks for the replys guys
I'm leaning towards the nt05 which has a 200 treadwear rating so should still have an ok life span under normal conditions
I've currently got ku36 been on the car for almost 2 years and for the last 6-9 months they have become the loudest most annoying tyres I'm changing them and they arnt even finished yet, proberbly done 15 passes at the drags and daily driving over 12000kms
They have a treadwear of 180
The KU36 are shit for that, they feather badly in the inner edge part!
RSR are much quieter and are OKish.... Even though they are a 140 treadwear they have lasted quite a while on mine!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
