Not so far but to be fair i havent really played with it to check.... They were brand spanking and still had writing on them so let me bed them in and ill check back in!
Actually on that note, i will know by the end of Sunday as its doing the Nulon Nats event :woot:
I'm sure it's the same for most tyres as the ad08r requires about 100km of driving to wear off the top shiny coating before the grippy part comes into play
  • Replies 54
Oh FFS then i better do some K's before it goes on the trailer this weekend then!
They look pretty bulgey compared to the old 275's i ran... You can see the difference between a 255RSR and a 275 RS3
If anyone wants the other pair of the 275/35/18 let me know... Will sell for what they cost me but i had to buy 4 to get the deal...
Brand new with stickers $512.50 for the pair :laugh:
Freight additional!
There was no magical grip that i was hoping for... 2nd gear is still skidsville BUT it was a road surface so it is not the best indication at this stage!
1265536_700169503374776_1002666072_o_zps
What tyre pressure and camber? They can affect the grip level as well
Yep, i was running 0 camber but it is now up to around -1.4 or something like that for circuit use.... In saying that i went from a 265 to a 275 in the hope the straight line contact patch would remain similar, but probably not lol
Pressure was about 30 hot so a bit low from a standing start.... But i did warm them up prior -
  • 1 month later...
That's a damn good price for 275 35 18!
I'd only put KU36s back on if Maria and I are having a domestic ;)
Lololol so you cant hear? Brilliant!
Oh and i changed my opinion on the RS3 too once i had them hot on the track, great tyre!
Told ya so Matty! :D
The rears had heaps of corner grip... Straight line had issues but i had it turned down to gate pressure for the run anyway...
After a few hard laps of South circuit the fronts (Federal RSR) would start to understeer yet i still had heaps of rear grip and no signs of it fading!
Its impressed me enough to step up to the next level of Hankook ;)
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
