Not so far but to be fair i havent really played with it to check.... They were brand spanking and still had writing on them so let me bed them in and ill check back in!
Actually on that note, i will know by the end of Sunday as its doing the Nulon Nats event :woot:
I'm sure it's the same for most tyres as the ad08r requires about 100km of driving to wear off the top shiny coating before the grippy part comes into play
  • Replies 54
Oh FFS then i better do some K's before it goes on the trailer this weekend then!
They look pretty bulgey compared to the old 275's i ran... You can see the difference between a 255RSR and a 275 RS3
If anyone wants the other pair of the 275/35/18 let me know... Will sell for what they cost me but i had to buy 4 to get the deal...
Brand new with stickers $512.50 for the pair :laugh:
Freight additional!
There was no magical grip that i was hoping for... 2nd gear is still skidsville BUT it was a road surface so it is not the best indication at this stage!
1265536_700169503374776_1002666072_o_zps
What tyre pressure and camber? They can affect the grip level as well
Yep, i was running 0 camber but it is now up to around -1.4 or something like that for circuit use.... In saying that i went from a 265 to a 275 in the hope the straight line contact patch would remain similar, but probably not lol
Pressure was about 30 hot so a bit low from a standing start.... But i did warm them up prior -
  • 1 month later...
That's a damn good price for 275 35 18!
I'd only put KU36s back on if Maria and I are having a domestic ;)
Lololol so you cant hear? Brilliant!
Oh and i changed my opinion on the RS3 too once i had them hot on the track, great tyre!
Told ya so Matty! :D
The rears had heaps of corner grip... Straight line had issues but i had it turned down to gate pressure for the run anyway...
After a few hard laps of South circuit the fronts (Federal RSR) would start to understeer yet i still had heaps of rear grip and no signs of it fading!
Its impressed me enough to step up to the next level of Hankook ;)
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I dried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4     I did the other 5 in less time than I fluffed around with the first one. I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the casing. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I overcome one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
    • Even back in the day, some importers were renowned for bringing in crashed cars, giving them a quick touch up + respray and making them look mint
    • No new updates from the op after covid, hopefully everything is ok...
