Hey All,
I have a 1996 R33 Series 2 which hates having the air con running! I have noticed that whenever it is on the car seems to miss on idle, kind of feels/sounds like it runs on three cylinders for a brief second. When the air con is off idle is perfect and I have no issues. Does anyone know what might be the cause of this? I had an ac idle up valve problem in my GT4 so am wondering if this might be the cause?
Any advice on what to investigate would be greatly appreciated :) I do have broken manifold stud bolts which are being taken care of this weekend but not sure if that is contributing in anyway.
Thanks
Em
https://www.sau.com.au/forums/topic/441117-why-does-my-r33-hate-air-con/
My 34 hates having the air-con running too. For some reason it effects the way my clutch engages? makes it
very difficult to shift and I also get the odd effect on my idle too, only drops rpm slightly but you can feel it stumble through the whole car.
I haven't got a clue whats wrong with it. The aircon is super cold and it still revs out okay.
Thanks guys! Cleaned the iac valve etc. Actually ran diagnostic codes and found out water temp sensor is faulty and for some reason the cold start valve wasnt even connected properly! Hopefully those things fixed will help at least! Haha weird isn't it re ur R34? Mine feels like it almost drops a cylinder occasionally on idle!
Hey Sparks, damn not yet! I actually cleaned my coolant temp sensor n the code went away- weird!! But it's still idling like ass now without air con :( haven't tried with air con tho! I assume worse lol. I did mess with the idle screw but it was shit before then. I'm wondering if throttle body or TPS maybe?
Hahaha ok well your Honda story makes me feel a bit better!
Sucks cos the car drives absolutely perfect otherwise :(
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
