Hey guys,
took my engine to my builder and found out that I was missing quite a few bits. What I need (all for 32 GTR):
Power steering pump brackets
2x AFMs
Coil packs (rb25 series 1 also compatible)
Coil pack brackets
coil pack loom
Crank angle sensor
aircon compressor bracket
fan blade
3 breather hoses from the top elbows (one drivers side to PCV valve and 2 on passenger side)
Y tube and following hoses to turbos
metal gearbox crossmember inserts that go in the rubber bushes
if you have anything that can help eg. a wrecked GTR, please PM me
https://www.sau.com.au/forums/topic/441127-wtb-bnr32-cas-coils-hoses-pipes-etc/
Ive got brand new Yellow Jackets coil packs for $420.00 delivered - http://performance-wise.com/userimages/procart27.htm
Ive also got brand new coil pack looms for $135.00 delivered - http://www.performance-wise.com/userimages/procart66.htm
Both products are great quality and come with local warranty. (Coils 2 yrs, loom 1yr)
If you purchase both at once, I can give you free express shipping.
PM me if you need any further info.
:cheers:
    • Holy hell! That is absolutely stunning! Great work!!!
