For Sale
C33 Laurel Full Cage bolt in jap spec... May Suit A31 Ceffy... $500
Wrapped in red padding for extra cool
C33 Laurel Headlights and Grill $200 good condish i have 2 sets
C33 laurel standard front bar (bit rough) $100
C33 Laurel Kevlar bonett lightweight stock coppy $200
C33 Stock Guards bit rough left and right $100 each
C33 Rear Lights and boot garnish $250 the pair good condish
C33 aftermarket fiberglass front bar Midnight purple very good condition $300 (G corporation) i have 2pcs
C33 boot lid good condition has some holes from a big spoiler in midnight purple $200
Cusco S14 Front coilovers $300
Profec B Spec $250
Djetro Power FC Suit 26 with FC datalogit and software(to connect to Laptop) $900 comes with Map Sensors and MAP Harness
(This can be used with a MSD window switch and run on a RB25)
Brand New Solid Diff Bushes suit R33,R34,S14,S15 $65
S14 LCAS $150 for left and right
R32 Brakes front with disks $250
R32 Brakes rear with disks $200
R32/s13 rear Subframe with Cusco Camber arms Cusco toe rods kazama traction rods. no diff or drive shafts chasing $400
All items located in Perth Western Australia
Can Ship at buyers expence
please no pms on here txt or email or call
ohhh409194818
britz1@gmail.com
Edited by britz1
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
