hi everyone first post on here =)
ok i need some help with my cefiro i have converted my one to a rb20det from a r32 (originally rb20e) i have sorted the wiring for the motor up to the dash loom, i have the r32 pinouts for these plugs but i need the ones for the cefiro so i can finish the wiring and actually drive the car, if anyone can help or has done the conversion please let me know how to get the dash loom plugged up! the poor car has been sitting for nearly 3 years and is screaming out for boost lol
i know this would have been covered many times but i cant find anything on it and none of the links work for me anymore
https://www.sau.com.au/forums/topic/441133-cefiro-wiring/
  • 1 month later...
  • 1 month later...
na sorry i never got anywhere trying to find them all you could do is if you have the a31 ecu loom is trace the wires from the ecu to the dash plugs off a r32 ecu pinout apparently they are the same then if you can get a r34 pinout you could match the wires to suit
https://www.sau.com.au/forums/topic/441133-cefiro-wiring/#findComment-7306816
na you have to modify to suit the dash loom and the plug by the afm is different aswell as i said the a31 and r32 has the same pinout on the ecu so you could trace the wires back to the plugs to the dash and rearrange them to suit or if you could get your hands on a a31 rb20de loom it would make the job easier because it will be plug and go
https://www.sau.com.au/forums/topic/441133-cefiro-wiring/#findComment-7307055
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
