All pics are here: http://1drv.ms/1fW8hcO
Can post some items.
R32 coupe door glass LH and RH, $15 each PICKUP only
R32 GTST Standard airbox $20
R32 front guards. All panels straight and rust free. LH (gold-suit repainting) $25 & 2xRH (1xgold-suit repainting) $25, (1xgunmetal grey one large scratch) $45. Pick up only.
R32 GTST rear bar (needs repainting), reo, reverse lights and number plate lights. $60 Pick up only
R32 GTST door cards LH & RH $15 each Pick up only
R32 coupe 2 x driver side window/mirror switch. $20 each
R32 coupe Passenger side window switch $5.
R32 climate control/aircon control box $10
R32 GTST gauge surround with switches shown in pic. $20
R32 assorted switches including clockspring and indicator stalk. $20
for the set shown in pic.
R32 radiator and fan shroud. Not sure if radiator leaks but looks ok. $20 for both. Pickup only.
R32 standard front strut brace $15 Pickup only.
R32 GTST type M side skirts, includes rear quarter skirts. Needs repainting, RH skirt has minor damage but hardly recogniseable when on the car. $40 for the set. Pickup only.
R32/R33 rear hicas lockbar $10.
R32 projector headlights RH and LH, $40 each.
R32 GTST clear aftermarket indicators, one of the tabs is broken but can easily be secured with zip ties. Sell as pair $40
R32 coupe rear taillights (needs repainting) $50 pair.
R32 coupe boot seal in excellent condition $5
R32 manual centre console surround, manual boot needs replacing. $15.
R32 blower motor fan $10
R32 coupe window motor assembly 1x LH & 2xRH. $10 each
R32 handbrake lever. $10.
R33 GTST rear Ohlins shocks and springs. Height adjustable (circlip) and damper adjustable, In good working order, no leaks. $50 set PICK UP ONLY.
R33 RB25DET Series 1 camshafts (set) $30
R33 RB25DET Series 1 factory coils, set of 6. $50
HKS mushroom pod filter suit RB. $15
Turbosmart Vee Port atmo bov. Bolt on for RB20/25 $20
Will consider straight swaps for:
Unmarked top half R33 dash.
Full R33 boot interior.
Edited by Alf
https://www.sau.com.au/forums/topic/441140-qld-various-r32-r33-parts/
Centre console surround, door cards, rear taillights, gauge (cluster) surround, rear Ohlins shocks and front bumper SOLD
Strut brace https://ljb9mg.dm2303.livefilestore.com/y2pbqpJCsEeRnRZatGzSvRWYrDzrMYZFYPAINiJxff9fsgjv6CyE6xxMFLO83jntgHJww91DrmBtU97XHFiqwdAJujbCuO2mv62-hVJ4qLtaXg/100_0056.JPG?psid=1
Can you put up a pic of the air box thanks. Might be interested pending the shape.
(Missing an air box and haven't any clue what they look like stock) sorry for the odd question.
Cheers
http://i1372.photobucket.com/albums/ag338/brian30det/100_0027_zpsf91a8258.jpg
http://i1372.photobucket.com/albums/ag338/brian30det/100_0026_zps9916a590.jpg
Brilliant, I'll take it please. I'll be able to make this work easier then folding up a alloy box I had in mind.
If you PM me your details ill deposit the money.
Regarding freight as I'm in adelaide. I can organise TNT to collect it from you if you could box it up and label it with some shipping details.
Thank you.
Chris,
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
