Bahaha well played! Haven't seen that one before. Lets hope this cyclone clears otherwise the rain is going to cause havoc.
If the rain is too bad we may have to just highway crawl down and have lunch. The mountain will be too dangerous if it's pissing down.
all of this ^
There are some 80kph limits towards the southern end of the mountain and Mike and I were 'seriously wtf' about that?
Considering how tight and twisty it is and add very old (banged up) bitumen, any form of wet weather will make that part of the mountain super treacherous and unforgiving
I wouldn't go all kneejerk about a little bit of rain that ye have been having today, it'll clear up tommorow and then you've got 5 full days for it to dry out..
No decisions will be made until the day. I'm fairly confident we'll be fine, just depends how long tail end of this cyclone hangs around.
are there any evos or z cars attending?,looks like a good group of cars are going.
Might have a couple of Z's but none confirmed, I've invited the Evo guys along but haven't heard anything yet.
It might just be because my skyline is mostly stock, but last time I went up Springbrook Rd (from Mudgeeraba) in the rain it wasn't a problem, even with old tyres (mostly light rain, but it varied) along with Pine Creed Rd and Nerang-Murwillumbah Rd is like a highway.
Or is the concern the NSW downhill section?
If the rain is good over Springbrook this week, I might have to head back to Brisbane via Nerang-Murwillumbah Rd so I can make a stop at the Springbrook Natural Bridge, instead of going back via the Motorway. Doubt I'll be bothered enough to go all the way back into Springbrook National Park to check out Purlingbrook Falls.
Edited by Terror
Nsw downhill section is narrow, not sure how rough it was, I guess its subjective since I wouldn't call any of the roads rough, though I'm used to the roads out here in the surat basin nowadays
Yah the problem is the downhill section in Nsw. I know that most of the drivers coming will be fine with some rain and slippery conditions but as an exec we need to consider everyone. I would rather change the rout or the date and have everyone sane than take to much of a risk and lose a car or have someone injured.
Having said that, the train will have to be fairly heavy for that to happen.
  • Like 1
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
