I just thought I'd start something where people can say all the dumb stuff they have found with there cars. When I was rebuilding my car I found the turbo was only held on by one bolt which is always good and they gearbox was put on twisted obviously done by a professional.
https://www.sau.com.au/forums/topic/441152-stupid-shit-found-with-your-car/
  • 9 months later...
Radiator thermostat switch was f**ked so the smart one re wired it to the air conditioning fan.:O
So to cool the car down gotta turn on aircon.
Btw it only taken about 30 mins to replace the switch.
Probably the same amount it taken him to rewire and soldier it in WTF:huh:
I really wounder about some guys lacking a brain:blink:
Edited by pol1on1
Forgotten to add; My wife's old Mazda left power windows never worked she said previous owner said, That the switch needs to only be cleaned out because coke splash into it
so I taken the hole door apart only to find no windows motor or mechanical but a wooden broomstick broken in half holding window in two spots.:angry:
And yes the old broom brush was still der
  • Like 1
I don't even remember making this thread lol. But We recently pulled apart my brothers sr20det, we found the exhaust manifold bolts were finger tight( all of them) and the alternator bolt was also finger tight 0.o
Well I did use a search bar typed in to it STUPID then found this it never kicked off.:unsure:
I know everyone who has bought a 2nd hand car found stupid shit
I hope it will get more post coz I really like reading others misfortune hehe lol:D
  • 1 year later...
Ok, time to leave my mark on this thread.
When we were looking for my Sender, in the fuel tank, we found a little syphon valve sitting around. So, at one point down the line in my cars life, some one stole fuel from the tank, yanked the hose out and the valve had been in there ever since.
Someone expandafoamed the entire boot. Was so heavy it wouldn't even pop up automatically.
This was the way the battery was held down. Apparently getting the correct sized battery was too hard, was cutting into the plastic.
Also he hacksawed off the thread on the gear shifter, and put a bit of plastic over the remaining metal, and threaded a new knob onto the plastic.. "Short" shifter.......
Edited by sleptema
  • Like 1
Besides the usual coins and receipts, nothing crazy.
I did find out that the rear parcel shelf in the Century stole all of the insulation from the other cars though :P
1896788_10152077922059272_1299506_n.jpg?
  • 2 months later...
Small packet of unknown substance that got flushed, Alternator came lose as it was not correctly bolted in, cheap sh!t coils that died, turbo has 1 stud threaded and the nut just kind of stuck half on, boost actuator hose made up of garden hoses, door skins missing almost all clips, Amp only half worked, Head Unit was Japanese, speakers are R-Type splits at the front and DD Linear coaxial at the rear with a cheap ass Boss amp that was half baked?? Front left calliper hydraulic fitting stripped, bald Chinese tyres, coil cover had 3 screw holding it in not 8, 5 of the clips on the coils were busted, alarm or immobiliser was dead so they just bypassed it.
think that it...
FOR NOW!
  • Like 1
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
