  • Replies 101
that's the other thing that shits me up the wall and then some about Sydney... the c0cky f**ks that run nightclubs and the fact that you have to wait HOURS regardless of if you have women with you or not. What's with that? Its changed progressively these days where it just ain't fun to go to commercial clubs these days... better goin to underground ones, low key bars and pubs. Never had that sort of thing in any of the other states i've visited
You just need to know what you're doing funky. They will keep you waiting all night and have next to no one inside unless you display the required attitude. Don't wait, don't line up, just walk straight to the front and tell them you are going in.
That said, I hate the rude pricks too. Shouldn't have to do this. I don't know the exact reason but I suspect that they only want confident outgoing people to go so they can all walk around boosting each others egos. If you meekly line up you don't fit the mould.
Hey, no baggin Canberra. We've got porn and fireworks and.....well that's about all.
Not really, my friend who lives in canberra tells me that fireworks are now illegal there too :);)
As for porn? I prefer sex. :)
Richard
As for porn? I prefer sex. :mad:
Richard
Fireworks are not illegal in canberra it is just the people who live there can't actually buy them.
As for Queensland it is not bad for a holiday but I don't think I could live there, although I have bought a unit up there.:D
Guest barbie iz a bitch
Snowman I used to live in cairns.. smack bang in the middle, even lived in "cairns st" !!Lived there for 6 years! nothing fantastic about it, it rained all through summer and it was always soooo muggy!!
........Blitz.. Only cute boys under the age of 22 can have the hotel room number :D
Wouldn't it be easier if you just called me by my sau nickname? :wassup:
Shit! Only 13 sleeps until im 22 :oops
Sorry for the hijack but I'm going to put my 1200cc injectors in before I put the HKZ td09 304/305 compressor housing wheel in the tubine housing wastegate because the efficiency of the thermal uptake is more likely to result in increased lag as opposed to response for my 5.43 AR housing outflow mechanism.
If you get what I mean.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
