A few months ago we bought a second-hand 3" dump pipe to replace the stock one in our R33 GTST. We looked under the car at the old one, then looked at the one we were buying, and thought they were the same.
The other day we removed the stock one, and realised that the new one was about 6" longer. As well as this, the flange that the cat bolts to is oriented different - ie rotated on the pipe so the holes don't line up.
Anyone know what this pipe might be out of? It is a commercially made one, with a brand name on it (which I can't remember - pipe is not here).
The turbo end mates up fine, and the pipe runs in the right place. The welded on mounting bracket at the cat end fits to the car's mounting point, but obviously the cat doesn't fit.
Any ideas on the best way to make it fit, without spending a small fortune at an exhaust shop?
Um.....define "small fortune". What are you expecting us to tell you? That you can whack it with a hammer and it will fit? I think it is pretty clear that if you want to connect it to your existing cat then you are going to have to cut the flange off, shorten the pipe and weld it back together so it mates with the cat. If there is some left-right offset or angle difference that means you can't make it connect, then you are better off removing the cat from the rear part of the exhaust and getting the mid pipe altered to suit.
  • Like 1
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
