Hi All,
Need your expert opinions. I had a forged RB26 built and run in around four years ago. Since then I had it removed and stored away. I am in the process of installing it in a new car and am wondering if there will be issues with it. I have heard from a not a very reliable source that cylinders can rust and engines can cease. Is this true? Are there tricks of the trade in getting an engine stored for this long started and going again?
Your opinions and advice is much appreciated!
Cheers.
It should have been spun manually every few mths, but in any case you could remove the spark plugs and throw like a cap full of oil in each cylinder and probably just add some thru the filler cap....But most important when its time to start unplug the cam sensor and turn it over for a while so some oil will circulate before actually starting.
It "should" be full off assembly lube and oil.
Pull the plugs out turn it over by hand
Further to the above. Leave tge plugs out when cranking it over so it doesn't kill the starter motor and wait for oil pressure to rise. Then refit the plugs and start it
The paranoid approach would be to chuck a borescope or one of those cheapearse fibreoptic cameras down a couple of plug holes to look at the bore walls. If there's any rust it should be visible. If there's not visible, breathe a sigh of relief and continue on as normal.
Do the manual lubing stuff described by the guys above before trying to get it going.
Brilliant guys!! Appreciate all your input. My brother has a micro camera GTSBoy so as a sanity check I might do what you suggested before I do what everyone else suggested in the way of lubing the engine again.
Thanks again all!
Definitely check the cylinders out, then I would throw some oil in them regardless, hand turn it over or use the starter with no spark plugs in.
Or you could just start it, probably will run fine and you'll know soon enough if it had enough oil/had any rust in it! (don't do this)
The obvious thing is chance all the fluids as well.
Edited by Rolls
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
