after bit more info and feedback re: quaife rear diff on the gtr, anyone running one of these yet?
not sure if its directly swap jobbie, unlike nismo items that require half shafts etc
who here is running one?
already had great things about the front but for the rears not sure if its better than nismo 1.5 option
https://www.sau.com.au/forums/topic/441222-quaife-rear-diff/
Hey Nesh, to have a chat with Terry at Award about rebuilding your standard diff tighter, that's the easiest and most likely cheapest way for pretty much the same result
I don't know about the rear diff but the quaife front diff is a gear résistance limo and doesn't 100% full lock which is what makes it so good for the front where you want the back it to full lock on acceleration
  • Like 1
bought front quaife diff, was chatting with owner of jjr, he swapped from nismo 1.5 to quaife rear, said difference was chalk n cheese, few other 32 gtr including donut king r35 has it in the rear, no chatter unlike nismo, maintenance free, lifetime warranty etc
has me leaning towards the quaife rear
When doing my rear I was tossing up between the quaife and the Nismo GT pro. I went the Nismo because the Quaife in the rear was just released and there was no feedback around, despite how good it was up the front.
The Nismo, on medium is way too much, I need to back it off and to get back that front drive that the quaife gave prob need to throw some extra friction plates into the transfer case. The Nismo (Atleast on medium) is one agro mofo.
How the quaife would go as a rear, it won't be a bad thing, may be super special but there isn't many people running one as they are so new.
  On 29/03/2014 at 12:31 PM, GTSBoy said:
Go drive an R34 (GTR). Nothing new there. Helical is helical.
Michael, you have both cars, you notice any difference hopping from one car to the other
the other thing to suss out is if quaife requires half shafts like the nismo or other mods
Yeah, their two completely different cars to drive on the edge is stock form, as far as drive line is concerned that is, the 34 doesn't always spin both back tyres in the middle of a turn unless pushed very hard making it a bit unpredictable and then by the time you've got them spinning the front has kicked in already pulling you straight, the 32 is the oppersite, in a straight line the 34 has sooo much more initial grip, but most of that is the transfer case being preloaded in the 34
http://m.youtube.com/watch?v=WpQETVmmS7w
At 1.15mins is an example of me pushing hard enough then 5secs later me pushing a bit to hard
I haven't punted it yet with the quaife in the front fitted
I have a spare R32 diff and new R34 gearing which I'm going to but in the rebuilt 32 diff and then jam it in the 34
pretty much in the same situation as OP..
option 1: rebuilt kit for r200 (250$ + was told about 400$ to rebuilt/retight the diff) should be tighter but not overly tight as a Nismo GT. no worries about bolt-on
option 2: buy a quaife because maintenance free, less chatter, drive smoothly but would still like to know if it's bolt-on affair.
option3: Go for a carbon diff ( most likely used, seen some from 600-1000), heard they were smoother, less maintenance and drive smoother than regular metal lsd.
  On 01/04/2014 at 1:15 AM, Ants said:
Well I have just purchased a quaife rear LSD.
Pretty certain it will need modification 'as early R32 cars will require the stronger later driveshaft flanges to use this' whatever that means.
correct, emailed Tim @ SVS and he confirmed using later model half shafts which are stronger as it has larger internal spine size, not a problem if your car is already late model 32 or 33/34 and non v-spec, straight bolt-on
  On 01/04/2014 at 2:39 AM, Piggaz said:
Did you happen to do the front too, Ants while the engine was out?
nah. If only I knew this then.
I will be doing the front soon as well.
But will test out rear first.
Yes I just picked one up too... so I got the front and rear! In a R33 GTR however.
  On 07/04/2014 at 7:40 AM, Ants said:
nice. When you did the front one how did that compare to standard setup?
The front one is right next to my foot still under my desk at work soon to be joined by the rear one! Slow build man, you will find out before me fortunately for you...
I think we got the last ones before the price rise too! :)
Lol I know that feeling having performance parts under the desk.
Yeah, that is BS re: price rise.
I really don't want to fork out almost $2K just for a diff when they are being sold for almost half that price in the states.
http://www.frsport.com/Quaife-QDF3L-ATB-Differential-Nissan-Skyline-GTR-R33-R34-front_p_29114.html
Just waiting upon some more diff bushes and new diff bearings and then will get it installed.
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
