Rb26 Air Regulator And Iac Valve
Hi and welcome to ! I'd be taking some pics of the plugs and wiring you've found and posting them up. The guru's on here will be able to get more from those than your descriptions of them.
By SeanR32GtSt · Posted
Just got to set up the sensor and run some wires for my tuner to install it to my haltech. -
Fair enough OP: If the car is a auto what's the trans fluid look like because the trans cooler in the radiator may have a issue If there's any milk shake on the trans dip stick you need to get that sorted pronto before the auto eats itself
Yeah. Particularly on cars where the maintenance, particularly the coolant maintenance, has not been up to scratch. Coolant turns acidic, eats the HX out, and at some point it becomes too thin to resist the pressure and you get horrible things happen. RBs are moderately famous for it. It's not like it's a problem that happens to all of them. But there've been enough events that people fear it.
