Badgaz Posted March 30, 2014 Share Posted March 30, 2014 +1 for BOV not helping the situation. I have an auto R33 atm and since putting a Blitz atmo on back off it almost stalls. But I live with it for the hektik doses it does .. I'd be pressure testing the system for leaks as they will also create stall issues along with the bov set-up.. mine use to stall a fair bit too..i run a greedy type rs bov and i've tightened it up a fair bit...before that i had some taiwanese bov and i could watch the piston stay open too long which would cause the car to nearly stall..then pickup again. having the spring pressure set correctly and the right size piping feeding your bov seems to be the right combination...also put zip ties or hose clamps over your airline to you bov. Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7243951 Share on other sites More sharing options...
ARTZ Posted March 30, 2014 Share Posted March 30, 2014 Damn you and your maturity superben.... Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7243961 Share on other sites More sharing options...
GTSBoy Posted March 30, 2014 Share Posted March 30, 2014 Even he has a bad day. 1 Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7244021 Share on other sites More sharing options...
wolverine Posted March 30, 2014 Share Posted March 30, 2014 The car was stock prior to the intake pipe change but did it have the factory BOV fitted? Has the idle been set correctly? Have you tested for intake leaks? Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7244028 Share on other sites More sharing options...
R33shaun Posted March 30, 2014 Share Posted March 30, 2014 tips for catching idle... 1. wait until it gets tired then bash with brick 2. drink beer and wait until it comes back on its own 3. trip idle with a stick 4. number 2 its easier and less tiresome 5. i believe a "profit" fits in my list somewhere or just drink beer and let future you sort that shit out 1 Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7244040 Share on other sites More sharing options...
nicksamaniac Posted March 30, 2014 Share Posted March 30, 2014 I'm loving this thread, you regular guys crack me up, love the comebacks! -You know who are Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7244213 Share on other sites More sharing options...
Ben C34 Posted March 30, 2014 Share Posted March 30, 2014 Damn you and your maturity superben.... I have been accused of a lot of things, maturity isn't one of them. I'm a little shocked,but I know you guys will support me through it. Anyway, back on topic, fix op's car or f**k off. Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7244226 Share on other sites More sharing options...
FawDawz Posted April 5, 2014 Author Share Posted April 5, 2014 Ha ha alright cheers lads. I've put everything back to stock to try and figure this out. Hooked up a boost gauge, works fine at reading boost while driving. However.. It reads 0psi when idling? Every other car I've owned and know of reads negative pressure. Tried 3 gauges and all do the same. It's an auto s1 stagea, is this normal? Was rhinking of hooking the gauge up to the vacuum on the fuel pressure reg to see if the system is okay. thanks a trillion Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7250064 Share on other sites More sharing options...
scotty nm35 Posted April 5, 2014 Share Posted April 5, 2014 Sounds like you hooked the boost gauge into the cooler piping, not after the throttle on the intake manifold like you should have. Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7250191 Share on other sites More sharing options...
Black4DR Posted April 6, 2014 Share Posted April 6, 2014 I took the guts out of my idle control and put a small manual lpg power valve (like a tap) in the line to the idle control. All sorted now. Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7250487 Share on other sites More sharing options...
Bushy Posted April 9, 2014 Share Posted April 9, 2014 As mentioned, pressure test. Link to comment https://www.sau.com.au/forums/topic/441237-rb25det-trying-to-catch-idle-when-backing-off/page/2/#findComment-7253932 Share on other sites More sharing options...
