Hi, hope someone can help me at this early hour, now it's abit irrelevant but I'm going to ask anyway. Now I have a ba xr6t (family shopping trolley) just a tune etc, but maxed out injectors, question is will my injectors from my rb26 work in the xr6t? I know the plug is different. But I'm running out of time and this would only be a temp fix. As gtr is off the road ATM, and I entered the xr6t in powercruise this weekend and havnt been able to get it on the track as I can't give it full jandel! As it's starving for fuel. Yesssssss I know I could go buy some. But I ain't got no bloody money at this point in time, as I spent it on tune etc on Thursday for this weekend thanks In advance for your help
https://www.sau.com.au/forums/topic/441245-injector-help/
Because I needed a solution yesterday. Doesn't matter now. Car was entered at powercruise, but was unable to get full throttle down as it would just cough n splutter, and I have a set of injectors here looking at me, and just needed to know if they were usable or not. All good now it's over. Also fried the brakes on the xr6 t. P.O.S!
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7245042
Less boost would have been a good start, but it wouldn't have done good skids.
I can only suggest a set of injectors, pretty cheap in the scheme of things. Sell your two small sets and buy a set of 1000's off me, would cost you nothing to upgrade to a decent set of Xspurts.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7245289
Unless MAP sensored ecu.
If the boost was beyond the mapping of the tune it would perhaps dump fuel to protect itself. I know if I was your tuner, and knew you were a fiddler, I would protect the hell out of it.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7246528
You know this is referring to my xr6t. It was a custom tune on there Dyno, using a sct x3 flash tuner I picked up. Got improved 30 rwkw then injectors were at 95%. He said he got most gains threw timing adjustment. And only got to put one pound more boost in, couldn't push it any further as it's a safe tune for a daily driven shopping trolley. It surges under full acceleration due to not getting enough fuel! It's a simple thing that happens to all of them as soon as you want more power.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7247094
Well, well, well!........ ( 3 holes in the ground) one would be left hoping that this is not the case, after paying for a proper tune, on the Dyno, rather then just uploading a flash tune, which IMO, isn't the best thing to do. So I've got 60lb injectors, just gotta get an intank pump, then I'll be taking it back. And it will be retuned at no cost.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7247587
Why wouldn't the tuner charge you? He tuned it on the crap you had, pushed it hard like you asked, and suddenly he is at fault when something changes on the car?
Pushing an injector past 80% is engine suicide, as there is no protection in the map to dump fuel when something goes wrong. Being a Ford doesn't help, as they are renowned for falling apart.
Did you buy second hand Siemens 60lb injectors? Don't cheap out on the pump, it will be working hard and there are a lot of knockoffs floating about on ebay etc.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7247946
Something changing? Was that way when I took it home, which was the night before powercruise. I didn't ask him to push it hard? The mrs uses it as a f**king daily. I asked for safe, reliable. Not a Dyno sheet queen. Which apparently wasn't available due too printer running out of paper. And tbh champ your talking like you know word for word, the conversation I had with the tuner? It was a simple question. It maybe be a ford, but I've owned it 2 months less then my gtr. And the ford hasn't spent most the time in the garage, due to things falling apart. Unlike the gtr. By the way your pissing me off with half cocked comments, so pipe down or shape up.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7248382
lol
phaggot
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7248387
So you actually asked your tuner for a tune which would push the injectors to 95%, and you think it was in some way safe?
Not trying to piss you off, just can't get my head around what you want to do. You can't modify a car and just ignore the fuel system, no matter how broke you are. It ends in tears every time...
I have the cheapest injector pricing in the country, if I can help you afford a decent set let me know. I'm here to help, half cocked or not.
https://www.sau.com.au/forums/topic/441245-injector-help/#findComment-7248606
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
