HI Guys up for sale is my 1989 R32 GTR
Please note that the car has club registration, and will most likely need to be repainted, there are cracks starting to appear as when is got painted the painter did't allow enough time for the primer to cure!!! f**king annoying.
I love the car! and have owned it for 2 years - only selling as i'm wanting a house. Wish i could live in the car, but i can't :(
MAY swap for a cheaper car and cash my way - offer me, you never know!
If you're interested text me 0430 084 005 - i don't come on here that often!
Anyway, here's the specs.
PRICE: $24,500
Exterior:
18x10 +20 offset 3 piece forged SSR wheels
Freshly Painted Black with a slight Violet pearl through it that you can’t see unless under bright sun
N1 lips (bonnet and boot)
Tinted windows
Standard wheels wrapped in Dunlop semi slicks
Outside looks completely standard and clean
Interior:
1992+ Dash and inserts
Clarion DVD player singe din head unit
Leather seats with perforated centre
6Point Cusco roll cage
Shift Light
Suicide switch
Boost Gauge on column
Nismo shifter
Original 5piece floor mats
All buttons and electrics work perfectly
Drive train
Engine:
Fully built RB26
CP pistons 20thou oversized
Spool Rods
R34 Crank (longer oil pump drive)
ACL Race series Bearings
Restricted oil galleries in the block
Eliminated oil squirt
Baffled Sump with gates
N1 Oil pump with billet gears (8bar oil pressure)
Cometic head gasket
Standard head (recoed and shimmed)
Cam gears
Painted Rocker Covers (HSV Senator Burgundy)
Cold Side:
Standard Plenum
600x300x100 Trust Intercooler
Hot Side:
Garrett -5 Turbo's (oil lines restricted also to cope with high oil pressure)
19psi actuators
3’ Dump pipes
3’ Front pipes to a 4’ collector
4’ Stainless steel exhaust with 2 magnaflow mufflers
Hks pod filters
Splitter welded into twin turbo pipe
ECU and Ignition:
Wolf V500 plug-in
Microtech X6 CDI
Splitfire Coil packs
Fuel System:
Bosch 1700cc new Indi injector (e85 ready)
Modified Fuel Reg
3ltr Surge Tank
2x 040 Bosch Euro Fuel pumps (mounted on twin pump bracket)
Misc:
Direct Clutches Race twin plate clutch
Drain Back Catch can EPA legal and sits in original battery location
Battery relocated in the boot
HID 6000k kit
HICAS Completely removed from front to back and lock bar put in
Antilag and flat shift has been tuned in
Slotted front rotors and drilled rears
All fluids were changed less than2000ks ago
K1NGTR plates also come with this car.
This car has been built from the ground up and comes with so many goods which were installed with care and done properly. There are probably lots of other things but I will add them as I remember.
Please I won’t tolerate test pilots or time wasters as I’m sure you wouldn’t either.
IMG_1340.jpg [/i][/indent]
  • Like 1
https://www.sau.com.au/forums/topic/441253-380kw-r32-gtr/
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
