  On 30/03/2014 at 3:50 AM, GTSBoy said:
A good aftermarket replacement is a lock bar.
And it shouldn't be bent. And if it is, then you should be worried about the drift/crash history of the car.
Thanks but I still want the hicas. .If I put a lock bar won't that not let the rear steering work and the car is immaculate except for that particular part?
You have to ask yourself how the rack got bent,and whether it was overlooked when repairing other damage on the car.
Not saying that the car has been damaged, but for the rack to get bent something fairly wrong has happened.
Most guys bin hicas.
Hey could someone please tell me what this part is called? And should it look slightly bent like in the photo. If not what Is a good replacement?
I posted in the previous post thinking it was the steering rack?
I think its the way the photo is taken
If it just bends towards the back of the car a bit then thats normal. If its bent any other way then you may have had rear end damageat some point in the cars history
From memory they have a bit of a kink to meet flush on the hub
Because HICAS sucks balls. It's up the back of the car fiddling with the rear steering when you're trying to hold a really high speed line or switching through the esses. Not what you want.
HICAS was intended to make a car drive better at 7/10. When you get up to 9/10 or more, YOU want to be the person deciding where the car's steering decisions are sending it, not some dumb arse computer with a 1980's program in it. What HICAS is supposed to do is start the back of the car turning earlier than if it wasn't there. (It's all about how slip angles are generated and THAT is far too complicated to go into here). But that's fine on a soft and boggy factory setup. You can make the car far more responsive with suitable bushing and suspension upgrades, negating the need for a complicated computer and electro/hydro/mechanical system.
+ it adds weight, complexity and things to go wrong. All of which should not be in a sports car.
  • Like 2
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 馃ゴ
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
