S13 Silvia race or drift car project. Full CAMS spec designed roll cage as per section J welded in joining all suspension points, side intrusion bars, harness bar etc. Cage is constructed of CAMS spec CDS mild steel tube using 44.45mm main hoop and 38.1mm for all other bars. Cage has not been log booked or inspected at this stage.
The shell has a modified firewall recessed to utilise RB series engine and move the motor back about 160mm on custom modified cross member. The RB26/30 and RB25det gearbox pictured is not included in the sale and shows the fitment location.
Shell has been lightened, all sound deadening removed and stripped of all wiring and other excess weight.
Has Wilwood race pedals with brake bias adjustability mounted on custom fabricated adjustable mount. Sparco seat and steering wheel are not included in the sale.
Overall the body is in excellent shape, shell is complied but will no longer be registered due to the cage and mods. Gearbox cross member has been made to suit RB25det box in the relocated position.
Not much needed to hit the track, you will need your own 4 stud wheels to roll as I currently don't have any.
If you would like to know more, inspect the vehicle or want a cage made for your vehicle give me a call or message. Located near Caboolture QLD
$3300.00
Thanks,
Matt
Zero 418719626
Can include an RB25det series 2 engine with Greddy copy plenum, loom, ecu for an extra $600.00. Motor has head removed for inspection, lump removed from exhaust port. Will need to be cleaned an re assembled. Motor was completely stock, manual with around 90k. Still have the standard plenum. Oil pump has been sold.
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 😢
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
    • yeah its just so expensive nowadays and its easy to lose motivation very quickly when you start adding up the costs. I acquired the car from a collector in Melbourne and was lucky to get the opportunity to buy something already completed.  I looked at a proper resto and your paying over 300-400K for a proper one (nut and bolt) so this one to me seemed like a much better option! Car is in private storage and for serious buyers, welcome to come see it/drive it in person (photos don't do it justice).
