Willing to trade for LMGT4
18x10.5+15 plus cash my way
What a coincidence Terry :P its a sign ;) hehe
But back on topic, can't believe this block is still for sale, such a rare piece, i need superpowers to rig my next lotto ticket :P
I am desperate - but only for the sake of paying for medication for my wife after kidney surgery
But thanks for the 5k offer sycorb
PM Sent.
If you buy Bill's GT500 Block, I will give you the official Nissan BNR34 M-Spec Brochure for free (if you still have yours). Honest - I have one.
You are a true gentlemen terry , I don't know what to say but thank you a lot and really appreciate your kind help . I will have to buy you a drink or feed when I see you next
Thank you
  • Like 1
Congratulations! If you still have a BNR34 M-Spec and don't own a Nissan BNR34 MSPEC Brochure, PM me with a picture of it and supply your address and I'll mail it to you. :)
  • Like 2
Thank you very much Terry, I'll send you a PM with the picture and address after I see Bill tomorrow :)
block is SOLD SOLD SOLD to a great GTR enthusiast and a truely great person . it was great to meet him in person and have a chat about cars .
seams like a small world in the car scene (we know the same people )
also a big thankyou to terry for his kindness and generosity .SAU is better for having him on board -thanks terry
mods please delete
  • Like 2
Thank you Bill for your kind words & for giving me the opportunity to own such a special item. It was an honour to have met such a genuine & strong hearted person like yourself. Truly an inspiration to all of us here at SAU. All the very best to you & your family :)
Guest
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
