R32 Nissan Skyline GTR 1989 imported by me in 2004.
I dont get the time to drive it, would like to see it go to a good home.
$14,500 or reasonable offer.
Located in Canberra but will trailer deliver to you for cost of fuel + hire.
http://www.gumtree.com.au/s-ad/mckellar/cars-vans-utes/1989-nissan-skyline-r32-gt-r/1042820101
https://www.sau.com.au/forums/topic/441282-fs-1989-nissan-skyline-r32-gt-r/
Last rego inspection:
- Back left handbrake was not applying full force.
- One of the engine mounts is split, don't know how long it was like it, never had an issue before, I bought a spare, haven't fitted it.
- Clear is coming off.
Needs a tune, throttle bodies need balancing. I cant afford to get it done.
It's pretty well stock, has steel wheel ball bearing turbos built by Croydon Motorsport, all the under plenum pipes were checked and replaced becuase the last mechanic overtightened the water bleed screw, so when I changed the water pump I couldnt bleed it, had to dismantle the entire inlet side. Found the paper gaskets blown in two laces so put in HKS metal gaskets.
Had the injectors serviced, removed the fuel tank and cleaned the lines out, new fuel lines as well. new timing belt went in a while ago.
Cat back exhaust, HKS Pods, everything else is stock.
My offer 10k plus cost of delivering to Sydney.
Not trying to insult or law ball you genuine offer before I buy gtr elsewhere this weekend.
Thanks
david
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
