You can get an e39 m5 for around 50k
Would be my pick. But 11-12 year old now
As Drew recommends, we've been tempted now and again to switch across to the E39 M5.
It needs to be low Kms to feel sure that you can sell it easily later on, as you Bobby concur.
We bought this 530i Individual (2003 model) for $28K back in 2009 with only 48,000Km.
It's now done 79,000Km for an 11 yr old car. We decided to keep it for a while yet.
You're welcome to test drive her (without being considered a tyrekicker).
looking at the inevitable time-consuming/expenses regarding Direct Injection, it really narrows your choice down (or at least defines what year/model you get). Lot of unhappy chappys with RS4's and mercedes.
personally... I'd get a pulsar :P
-1 to MPS. Cobb tune and exhaust will push 160fwkws. they claim 190 at the flywheel from factory...
but would do some reading up on the newer volvos.
http://www.carsales.com.au/dealer/details/Volvo-S60-2011/AGC-AD-15268958/?Cr=0&sdmvc=1
wont need diff due to AWD, but exhaust and flash tune would make more exciting.
Tez, back off, the N1 is mine.
Bobby, get some Audi love on man, they are great cars and the S4's are big value for money, stick a set of pipes on and pull chicks.
  • Like 1
Thanks guys, appreciate all the help.
Not sure a Focus is for me. Great cars, but maybe a little more for someone in their mid to late 20's. Just my view.
Was after something a little more luxuirous, hence the V36.
Go test drive one and I'm fairly certain you'll change your tune.
Put a fully specc'ed (and for $50 you can tick every box) Focus ST against any 10+ year old Beemer or Audi, and the Focus will kick the shit out of it in every way.
Hate to say that I reckon the ST was quicker in the twisties than my modded R32 GTR. It has more useable power down low due to being lighter. It surprised the hell outta me, being a RWD 6 cyl traditionalist.
  • Like 1
I'll throw in another vote for the IS-F. I've seen 2008 models for less than $60K with less than 50000kms . Insurance is also pretty reasonable when compared to the Euros, roughly 20% cheaper for me. The MY10s are the ones to get as they have the proper LSD but they're still around the $70K mark.
S5s are going for $10-15K more for similar age/ks, definitely a stunning car but well short of the 400hp of an IS-F.
From what I've read IS-Fs have very few issues (the odd rattle mainly) where as most of the Euros I'd be reluctant to pick up unless it came with extended factory warranty.
The S5, 135i & 370Z would be my also rans.
Is the Golf R going to be sold in Australia? It might sneak in under $50K new, and as long as you sell it before the warranty runs out you should be fine. 296hp, 4WD, 0-100 in 5.1, 4-door hatch.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
