Hey SAUer's,
need to clear items asap!
Location is in Patterson Lakes 3197 (South East Melbourne), VIC
Prices are negotiable.
Contact details: OJ on 0423 932 035 (text, call or PM)
R33 Parts
Parts off a 96' r33 gtst
R33 Black Boot lip/ Drift wing - $180
R33 Stock turbo (no actuator) minor shaft play - $150
post-84763-0-00345400-1396258037_thumb.jpgpost-84763-0-66542500-1396260638_thumb.jpgpost-84763-0-29228000-1396260674_thumb.jpgpost-84763-0-39217800-1396260707_thumb.jpg
R33 Stock turbo (with actuator) major shaft play - $200
post-84763-0-59869900-1396260496_thumb.jpgpost-84763-0-43628100-1396260533_thumb.jpgpost-84763-0-36960900-1396260572_thumb.jpgpost-84763-0-62476400-1396260608_thumb.jpg
R33 Black Rear left tail light (has small crack in it) - $60
R33 Indicator (working & good condition) - $40
R33 lowered suspension set (1x rear leaking, the one with the duct tape around it) - $180
R33 stock suspension set (good condition, just took them out recently) - $220
post-84763-0-40684400-1396258242_thumb.jpgpost-84763-0-03910100-1396258332_thumb.jpgpost-84763-0-82786400-1396258383_thumb.jpg
R33 stock front pipe with cat together - $200
R33 drive side headlight (series 1) (has molded mount) - $80
post-84763-0-77465600-1396258119_thumb.jpgpost-84763-0-10776100-1396258158_thumb.jpgpost-84763-0-60177800-1396258193_thumb.jpg
Kicker 6x9 parcel shaft speakers (still works) - $80
post-84763-0-98757100-1396258472_thumb.jpgpost-84763-0-62949200-1396258507_thumb.jpgpost-84763-0-92650200-1396258544_thumb.jpg
Lenso Rims 19x8+2 set (all round), excellent tread front and back.
front 235/35/19 (achilles rubber)
rear 245/35/19 (Zeetex rubber)
post-84763-0-76184900-1396258918_thumb.jpgpost-84763-0-74725300-1396258972_thumb.jpgpost-84763-0-96405000-1396258980_thumb.jpgpost-84763-0-72052500-1396258989_thumb.jpgpost-84763-0-53225300-1396258964_thumb.jpg
was a silver with polished chrome lip until i plasti dipped them black. (see my skyline photo of what they used to look like)
180sx Parts
Parts off a 96' type x.
Fujitsubu 3" exhaust front pipe back (with decat) - $500
Stainless steel 3" front pipe for 180sx, has a 2.5" inlet - $80
Stock Springs (front and rear) - $150
180sx Garret stock turbo (minor shaft play) - $180
post-84763-0-99471000-1396260769_thumb.jpgpost-84763-0-92077000-1396260799_thumb.jpgpost-84763-0-38121600-1396260845_thumb.jpgpost-84763-0-27673100-1396260881_thumb.jpg
Holden Part
Part off a VL Commodore
whole set of Holden 15" stockies (bald tyres) - $140
Location: Patterson Lakes 3197 (South East Melbourne), VIC
Prices: All negotiable!
Price drop on specific items:
Turbos: $140 each
Fujitsubu 3" exhaust front pipe back (with decat) - $400
Stainless steel 3" front pipe for 180sx, has a 2.5" inlet - $60
Stock Springs (front and rear) - $120
3x Holden 15x6.5'' stockies (bald tyres) - $80
R33 Black Rear left tail light (has small crack in it) - $50
R33 lowered suspension set (1x rear leaking, the one with the duct tape around it) - $160
R33 stock suspension set (good condition, just took them out recently) - $180
R33 stock front pipe with cat together - $160
R33 drive side headlight (series 1) (has molded mount) - $50
Kicker 6x9 parcel shaft speakers (still works) - $70
Lenso Rims 19x8+2 set with excellent tread tyres - $750
Buy 2 or more items and you'll save more!
I need these gone by mid June as im moving houses.
Contact me on 0423 932 035 or PM me
parts still for sale!
Turbos: $140 each
 Share
    • Haha honestly the thought crossed my mind but skylines are so damn rare here someone would probably hang me 😂    I’ve had a few LS swapped cars (280zx and a foxbody mustang) so trying something a bit different this time
    • Not much info in that request..... If you have a VIN you could look up the factory part number here: https://www.amayama.com/en/genuine-catalogs/nissan
    • 2.5 torque? 3.0 torque? Pft. Dude the van is right there. Consolidate your projects, put the LS into the R32 and have either a R32 with grunt, or a firebird that handles, however you want to refer to it. Either way you won't want to drive the Firebird or a RB powered Skyline ever again so this is the proper solution, and you cut down on projects. It makes sense even if you hate it.
    • Never mind the ash - the massive witness mark on the leading edge of the rear arch make little baby jesus cry.
    • Some small fixes made over the weekend. I've been trying to get the car sitting right on the 275's as well as reducing the rubbing as much as possible. I bought a guard roller but the lip within the guard is obviously made of high tensile steel because it took so much work and heat to get the smallest of movements that I totally flared my rear arches. It looks kinda cool.   I also got inside the arches with a dremel to cut down the bumper and the bumper mounts. The first one (pictured) got a bit ugly but the next one was much nicer as I just cut slots and hammered them upwards. I gave it all a spray of primer too. I'm still scrubbing a little bit on passenger side but it has less camber than the drivers, so once that is sorted it *should* be ok. I drop a single corner down on the ramp to simulate that mismatch and see where it is scrubbing.         Here's my flares. The car is lower than this now. Excuse the bush fire ash on the car.    I also haven't had windscreen washer jets for weeks so thought I'd tackle that. It looks like a leak is coming from under the headlight. Just in there. See it?  This would have been clearer and easier if I'd taken the front bar off, but basically the plastic hose connector has broken off the headlight sprayer. And because I couldn't be arsed taking the bar off and fixing what is already a gimmick, I just disconnected the feed hose and with some aquarium hose, circlamps and a drive shaft bolt I fixed it good. The hex piece I tried first did not seal too well (2nd pic) - not sure why I thought it would! 🤦‍♂️.   Because I hate things being broken, I will fix this, but until I could be bothered to take my bar off, this will suffice. Note the BMW push-in hose connector. Because standardised fittings are too passé. I now have an issue with my adaptive headlights always pointing too low and sometimes shaking back and forth when I'm driving. I'm keen to have these working properly. On another note, I bought a set of EBC BlueStuff for the front. I looked at so many reviews; DBA Xtreme (not enough reviews), Ferodo DS2500 (Super expensive and hard to find), Hawk HP+ (hard to find, not many track/street combo reviews) and some others. Was able to get the Blues pretty cheap (~$250 delivered). Also there's a motorsport joint in Hornsby that will supply and install a RacingDiffs LSD conversion for $850 which is pretty good. I know its not a proper LSD but I'm just not keen right now to spend $3500+ on a proper one. I figure I'll give this a go and see what its like, if nothing breaks I can sell the diff with this in and upgrade later if I want. There are some streets near me I cannot get up in the wet at all and just spin a lot in the dry, it would be nice to have traction on these. (I live on a big hill). My first ever skid pan is coming up on the 8th of Nov. Can't believe I've never done one. Really looking forward to it.
