hey guys...well my drivers side pwr window has finally decided to cack it. it started makin this terrible gurgling noise when i went to put it down and just stopped. after a long pokin session yesterday i finally got the window back up by pressin the switch and manually pushin the window up from the cavity of the door to help the motor along. im assuming the motor is on its last legs. just wanted to know where exactly is the motor found in side the door and is it easy to change?? attached is a pic of where i think the motor is. any hints tips would be apreciated
cheers
https://www.sau.com.au/forums/topic/44132-wheres-the-power-window-motor/
Pretty close. move the circle about 10cm right and 10cm down and that's where the motor and drive gear are.
To get it all out, you have to unbolt at about 4 points. I can't add to your image at the moment, but you have to unbolt the bar from the bottom of the glass, the two bolts that are in the slots above the large hole. You don't have to move that long vertical bar to the right that the window runs down.
Basically, the whole mechanism is a scissoring setup... disconnect all the bolts, undo it from the glass, fold it down, then you can pull it out through that large cavity. I'll tell you now, be VERY careful when removin the motor/gear from the 'frame' thing once you've got it all out of the door. There's a high pressure spring on there. When I took mine off, it whipped around and sliced straight through my thumbnail.
You'll have to have it up to unbolt the lower mechanism, then the glass will slide down of it's on weight... might want to ask someone to hold it for you until you're ready... then let it slide down, wiggle off the bar that attaches to the glass, collapse the whole thing and slide it out the hole.
My thumb is not famous, it just has many friends.
And yeah, it's roughly the same to put back in as taking out. Probably easier, because you know where it all goes.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
