Kindness & Compassion
Remember guys, if you're up to it...
A donation tin for Bowel Cancer Aust will be on deck to receive any $$$ you can spare!
The tin will then be passed to NYTSKY (Dave) a long standing Member of SAU.NSW and his partner Anneke to help with Bowel Cancer Research.
Many Thanks In Advance For Your Grace!
  • Like 2
I can take people in but not back to penrith
Hi Jason,
Thanks for that. Flight# 740iL will contain 5x
Perhaps 1x will enjoy your passenger seat more than the Bimmer's rear jump seat on the way to Riverwood ;)
C U at Kendall St say at 12.35
Hi Jason,
No worries terry see you soon
Thanks to Theo for putting this on and to Terry for organising.
Here are some photos.
14170654423_9e648cd6d6_b.jpgDSC_0003 by Crashdown55, on Flickr
13963921467_ef5dd98f9a_b.jpgDSC_0005 by Crashdown55, on Flickr
14150609085_0b77f4ac64_b.jpgDSC_0006 by Crashdown55, on Flickr
13963918467_21a6b6e614_b.jpgDSC_0008 by Crashdown55, on Flickr
14170648313_28981125c3_b.jpgDSC_0009 by Crashdown55, on Flickr
14150605405_7b9675a102_b.jpgDSC_0010 by Crashdown55, on Flickr
14150603735_865011d845_b.jpgDSC_0012 by Crashdown55, on Flickr
13963954158_ed61df2b8b_b.jpgDSC_0015 by Crashdown55, on Flickr
13963953168_788f08df0b_b.jpgDSC_0016 by Crashdown55, on Flickr
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
